I am recently developing a force-controller robot using ODrive. I found a lot of tutorials but no one could tell me how to do the torque control using PWM. Does ODrive support torque control using PWM?
Best regards,
Chao
Best regards,
Chao
e.g.
odrv0.config.gpio4_mode = GPIO_MODE_PWM
odrv0.config.gpio4_pwm_mapping.min = -2
odrv0.config.gpio4_pwm_mapping.max = 2
odrv0.config.gpio4_pwm_mapping.endpoint = odrv0.axis0.controller._input_torque_property
Don’t forget to configure an appropriate vel_limit or disable torque_mode_vel_limit
Thank you so much.
I tried to disable the velocity limit by “odrv0.axis0.controller.torque_mode_vel_limit = False” and “odrv0.axis0.controller.enable_torque_mode_vel_limit = False”, but it returns with error “AttributeError: Attribute torque_mode_vel_limit not found” and “AttributeError: Attribute enable_torque_mode_vel_limit not found”, respectively.
Additionally, I got one more issue about the PWM torque mapping. I will new a topic to discuss this issue.
Best regards,
Chao
