Hi! You can only call functions over USB and CAN. Is it an option to switch to CAN for your application? What specifically are you looking to read over GPIO?
I have tried to setup the CAN-bus, but I am using an ESP32. I have lot of experience with the ESP32. Eg. I am using the double kernel. I have tried to setup CAN with the pull request for the ESP32 Odrive github library, but after several weeks of efforts I have gven up! I was able to get it compiled but newer working. As for now I am reluctant of switching to Teensy 4.1.
My objective with the GPIO is to get the Endstop and Homing up and running as described in the API. First I am attempting to get the GPIO running as a simple I/O.
I anticipate your answer also implies that I will newer be able to use the save_configuration() nor the reboot() procedures over the UART-communication.
