I’m attempting to perform a simple calibration of my ODrive system in torque control mode, measuring the difference between the requested and measured torque by determining a “torque offset” value (e.g. odrv0.axis0.controller.input_torque = T_request + T_offset) that enables the motor to suspend a known weight off of a pulley at 0 RPM.
Above a certain input_torque value, the system current (per both Iq_setpoint and Iq_measured) is limited to precisely 25A, despite my current_limit being set to 60A (I’ve made sure to save and reboot the controller after changing that limit).
I’ve tried changing requested_current_range up to 80A out of curiosity, no change in the behavior.
Could this be a thermal issue? The system doesn’t throw errors, and it also happens independently of how long I’ve had the system energized.
Any insight is greatly appreciated, I’m stumped. Hardware and configuration settings follow.
Hardware:
ODrive v3.6 controller, 56V version
single ODrive D5065 270KV motor running through a 20:1 reduction planetary gearbox
Power supply: 24V, max 41.7A / 1000W
Controller/firmware settings (dumping a bunch here, in case I’m missing something)
Settings under odrv0.axis0.config:
calibration_lockin:
accel: 20.0 (float)
current: 10.0 (float)
ramp_distance: 3.1415927410125732 (float)
ramp_time: 0.4000000059604645 (float)
vel: 40.0 (float)
can:
encoder_rate_ms: 10 (uint32)
heartbeat_rate_ms: 100 (uint32)
is_extended: False (bool)
node_id: 0 (uint32)
dir_gpio_pin: 2 (uint16)
enable_sensorless_mode: False (bool)
enable_step_dir: False (bool)
enable_watchdog: False (bool)
general_lockin:
accel: 20.0 (float)
finish_distance: 100.0 (float)
finish_on_distance: False (bool)
finish_on_enc_idx: False (bool)
finish_on_vel: False (bool)
vel: 40.0 (float)
sensorless_ramp:
accel: 200.0 (float)
finish_on_vel: True (bool)
vel: 400.0 (float)
startup_closed_loop_control: False (bool)
startup_encoder_index_search: False (bool)
startup_encoder_offset_calibration: False (bool)
startup_homing: False (bool)
startup_motor_calibration: False (bool)
step_dir_always_on: False (bool)
step_gpio_pin: 1 (uint16)
watchdog_timeout: 0.0 (float)
Settings in odrv0.axis0.motor:
DC_calib_phA: 0.22347372770309448 (float)
DC_calib_phB: -0.3492250442504883 (float)
DC_calib_phC: 0.1259220540523529 (float)
I_bus: 0.0 (float)
config:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
current_control_bandwidth: 1000.0 (float)
current_lim: 60.0 (float)
motor_type: 0 (uint8)
phase_inductance: 1.6069736375357024e-05 (float)
phase_resistance: 0.052728693932294846 (float)
pole_pairs: 7 (int32)
pre_calibrated: False (bool)
requested_current_range: 80.0 (float)
torque_constant: 0.03999999910593033 (float)
torque_lim: inf (float)
current_control:
Ialpha_measured: 0.0 (float)
Ibeta_measured: 0.0 (float)
Id_measured: 0.0 (float)
Id_setpoint: 0.0 (float)
Iq_measured: 0.0 (float)
Iq_setpoint: 0.0 (float)
Vd_setpoint: 0.0 (float)
Vq_setpoint: 0.0 (float)
final_v_alpha: 0.0 (float)
final_v_beta: 0.0 (float)
i_gain: 52.72869110107422 (float)
p_gain: 0.01606973633170128 (float)
phase: 0.0 (float)
phase_vel: 0.0 (float)
power: 0.0 (float)
v_current_control_integral_d: 0.0 (float)
v_current_control_integral_q: 0.0 (float)
current_meas_phA: -0.22057965397834778 (float)
current_meas_phB: 0.3485667407512665 (float)
current_meas_phC: -0.12793013453483582 (float)
effective_current_lim: 60.0 (float)
error: 0 (uint64)
fet_thermistor:
config: ...
temperature: 30.631746292114258 (float)
is_armed: False (bool)
is_calibrated: False (bool)
last_error_time: 0.0 (float)
max_allowed_current: 121.5 (float)
max_dc_calib: 12.15000057220459 (float)
motor_thermistor:
config: ...
temperature: 0.0 (float)
n_evt_current_measurement: 1619158 (uint32)
n_evt_pwm_update: 1619161 (uint32)
phase_current_rev_gain: 0.05000000074505806 (float)
Settings in odrv0.axis0.controller:
anticogging_valid: False (bool)
autotuning:
frequency: 0.0 (float)
pos_amplitude: 0.0 (float)
torque_amplitude: 0.0 (float)
vel_amplitude: 0.0 (float)
autotuning_phase: 0.0 (float)
config:
anticogging: ...
axis_to_mirror: 255 (uint8)
circular_setpoints: True (bool)
control_mode: 1 (uint8)
electrical_power_bandwidth: 20.0 (float)
enable_torque_mode_vel_limit: True (bool)
enable_vel_limit: True (bool)
homing_speed: 0.25 (float)
inertia: 0.0 (float)
input_mode: 1 (uint8)
load_encoder_axis: 0 (uint8)
mechanical_power_bandwidth: 20.0 (float)
mirror_ratio: 1.0 (float)
pos_gain: 20.0 (float)
spinout_electrical_power_threshold: 10.0 (float)
spinout_mechanical_power_threshold: -10.0 (float)
steps_per_circular_range: 1024 (int32)
torque_mirror_ratio: 0.0 (float)
torque_ramp_rate: 0.009999999776482582 (float)
vel_gain: 0.10000000149011612 (float)
vel_integrator_gain: 0.0 (float)
vel_integrator_limit: inf (float)
vel_limit: 10.0 (float)
vel_limit_tolerance: 1.2000000476837158 (float)
vel_ramp_rate: 1.0 (float)
electrical_power: 0.0 (float)
error: 0 (uint8)
input_pos: 0.0 (float)
input_torque: 0.0 (float)
input_vel: 0.0 (float)
mechanical_power: 0.0 (float)
move_incremental(obj: object_ref, displacement: float, from_input_pos: bool)
pos_setpoint: 0.0 (float)
start_anticogging_calibration(obj: object_ref)
torque_setpoint: 0.0 (float)
trajectory_done: True (bool)
vel_integrator_torque: 0.0 (float)
vel_setpoint: 0.0 (float)
