Sounds a bit overkill, but of course ODrive can certainly do it if the motor can.
But, you’d probably need quite a powerful motor e.g. a hoverboard wheel (or use a gearbox as you say) to get that kind of torque.
True, a sensorless ESC won’t have enough starting torque, but one using Hall sensors would work fine. It wouldn’t have precise velocity control either, but do you really need that for grinding coffee?
If you are building a robot arm to crank the handle on a manual mill, then yeah you need ODrive for that
