Here the configs from S1 and Pro. They are for slightly different motors.
I have to insert the text:
S1:
{“axis0”: {“commutation_mapper”: {“config”: {“approx_init_pos”: 0.0, “approx_init_pos_valid”: false, “circular_output_range”: 1.0, “circular”: true, “index_gpio”: 7, “index_offset”: 0.0, “index_offset_valid”: false, “offset”: 0.0, “offset_valid”: true, “passive_index_search”: false, “scale”: 1.0, “use_endstop”: false, “use_index_gpio”: false}}, “config”: {“I_bus_hard_max”: Infinity, “I_bus_hard_min”: -Infinity, “I_bus_soft_max”: Infinity, “I_bus_soft_min”: -Infinity, “P_bus_soft_max”: Infinity, “P_bus_soft_min”: -Infinity, “calib_range”: 0.019999999552965164, “calib_scan_distance”: 8.0, “calib_scan_vel”: 2.0, “commutation_encoder_bandwidth”: NaN, “commutation_encoder”: 8, “dir_gpio_pin”: 9, “enable_error_gpio”: false, “enable_step_dir”: false, “enable_watchdog”: false, “encoder_bandwidth”: 100.0, “error_gpio_pin”: 10, “index_search_at_target_vel_only”: false, “load_encoder”: 8, “startup_closed_loop_control”: false, “startup_encoder_index_search”: false, “startup_encoder_offset_calibration”: false, “startup_homing”: false, “startup_max_wait_for_ready”: 3.0, “startup_motor_calibration”: false, “step_dir_always_on”: false, “step_gpio_pin”: 8, “torque_soft_max”: Infinity, “torque_soft_min”: -Infinity, “watchdog_timeout”: 0.0, “anticogging”: {“calib_bidirectional”: true, “calib_coarse_integrator_gain”: 100.0, “calib_coarse_tuning_duration”: 60.0, “calib_end_vel”: 0.07000000029802322, “calib_fine_dist_scale”: 1.0, “calib_fine_tuning_duration”: 120.0, “calib_start_vel”: 4.0, “enabled”: false, “max_torque”: 0.15000000596046448}, “calibration_lockin”: {“accel”: 3.183098793029785, “current”: 4.0, “ramp_distance”: 0.5, “ramp_time”: 0.4000000059604645, “vel”: 6.36619758605957}, “can”: {“bus_voltage_msg_rate_ms”: 0, “encoder_msg_rate_ms”: 0, “error_msg_rate_ms”: 0, “heartbeat_msg_rate_ms”: 100, “iq_msg_rate_ms”: 0, “node_id”: 3, “powers_msg_rate_ms”: 0, “temperature_msg_rate_ms”: 0, “torques_msg_rate_ms”: 0, “version_msg_rate_ms”: 0}, “general_lockin”: {“accel”: 20.0, “current”: 10.0, “finish_distance”: 100.0, “finish_on_distance”: false, “finish_on_vel”: false, “initial_pos”: 0.0, “ramp_distance”: 3.1415927410125732, “ramp_time”: 0.4000000059604645, “vel”: 40.0}, “motor”: {“acim_autoflux_attack_gain”: 10.0, “acim_autoflux_decay_gain”: 1.0, “acim_autoflux_enable”: false, “acim_autoflux_min_Id”: 10.0, “acim_gain_min_flux”: 10.0, “acim_nominal_slip_vel”: 2.3399999141693115, “bEMF_FF_enable”: false, “calibration_current”: 4.0, “current_control_bandwidth”: 100.0, “current_hard_max”: 110.0, “current_slew_rate_limit”: 10000.0, “current_soft_max”: 90.0, “direction”: 1.0, “ff_pm_flux_linkage”: 0.0, “ff_pm_flux_linkage_valid”: false, “fw_enable”: false, “fw_fb_bandwidth”: 500.0, “fw_mod_setpoint”: 0.7813565135002136, “motor_model_l_d”: 0.0, “motor_model_l_dq_valid”: false, “motor_model_l_q”: 0.0, “motor_type”: 0, “phase_inductance”: 6.874503014842048e-05, “phase_inductance_valid”: true, “phase_resistance”: 0.05476512014865875, “phase_resistance_valid”: true, “pole_pairs”: 7, “power_torque_report_filter_bandwidth”: 8000.0, “resistance_calib_max_voltage”: 10.0, “sensorless_observer_gain”: 1000.0, “sensorless_pll_bandwidth”: 1000.0, “sensorless_pm_flux_linkage”: 0.0, “sensorless_pm_flux_linkage_valid”: false, “torque_constant”: 0.030629629269242287, “wL_FF_enable”: false}, “sensorless_ramp”: {“accel”: 31.83098793029785, “current”: 10.0, “finish_distance”: 15.915493965148926, “finish_on_distance”: false, “finish_on_vel”: true, “initial_pos”: 0.0, “ramp_distance”: 0.5, “ramp_time”: 0.4000000059604645, “vel”: 63.6619758605957}}, “controller”: {“config”: {“absolute_setpoints”: false, “circular_setpoint_range”: 1.0, “circular_setpoints”: false, “commutation_vel_scale”: 1.0, “control_mode”: 2, “enable_gain_scheduling”: false, “enable_overspeed_error”: true, “enable_torque_mode_vel_limit”: true, “enable_vel_limit”: true, “gain_scheduling_width”: 0.0010000000474974513, “homing_speed”: 0.25, “inertia”: 0.0, “input_filter_bandwidth”: 2.0, “input_mode”: 2, “pos_gain”: 1.0, “spinout_electrical_power_bandwidth”: 20.0, “spinout_electrical_power_threshold”: 10.0, “spinout_mechanical_power_bandwidth”: 20.0, “spinout_mechanical_power_threshold”: -10.0, “steps_per_circular_range”: 1024, “torque_ramp_rate”: 0.009999999776482582, “use_commutation_vel”: false, “use_load_encoder_for_commutation_vel”: false, “vel_gain”: 0.20000000298023224, “vel_integrator_gain”: 0.5, “vel_integrator_limit”: Infinity, “vel_limit”: 40.0, “vel_limit_tolerance”: 1.2000000476837158, “vel_ramp_rate”: 30.0}}, “enable_pin”: {“config”: {“debounce_ms”: 50, “enabled”: false, “gpio_num”: 7, “is_active_high”: false, “offset”: 0.0}}, “interpolator”: {“config”: {“dynamic”: true}}, “max_endstop”: {“config”: {“debounce_ms”: 50, “enabled”: false, “gpio_num”: 0, “is_active_high”: false, “offset”: 0.0}}, “mechanical_brake”: {“config”: {“gpio_num”: 0, “is_active_low”: true}}, “min_endstop”: {“config”: {“debounce_ms”: 50, “enabled”: false, “gpio_num”: 0, “is_active_high”: false, “offset”: 0.0}}, “motor”: {“motor_thermistor”: {“config”: {“beta”: 3435.0, “enabled”: true, “gpio_pin”: 4, “r_ref”: 10000.0, “t_ref”: 25.0, “temp_limit_lower”: 100.0, “temp_limit_upper”: 120.0}}}, “pos_vel_mapper”: {“config”: {“approx_init_pos”: 0.0, “approx_init_pos_valid”: false, “circular_output_range”: 1.0, “circular”: false, “index_gpio”: 7, “index_offset”: 0.0, “index_offset_valid”: false, “offset”: 0.0, “offset_valid”: false, “passive_index_search”: false, “scale”: 0.1428571492433548, “use_endstop”: false, “use_index_gpio”: false}}, “trap_traj”: {“config”: {“accel_limit”: 0.5, “decel_limit”: 0.5, “vel_limit”: 2.0}}}, “can”: {“config”: {“baud_rate”: 250000, “protocol”: 1}}, “config”: {“dc_bus_overvoltage_trip_level”: 52.0, “dc_bus_undervoltage_trip_level”: 10.5, “dc_max_negative_current”: -1.0, “dc_max_positive_current”: 120.0, “enable_uart_a”: true, “gpio0_mode”: 17, “gpio10_mode”: 17, “gpio11_mode”: 17, “gpio12_mode”: 4, “gpio1_mode”: 17, “gpio2_mode”: 17, “gpio3_mode”: 17, “gpio4_mode”: 17, “gpio5_mode”: 17, “gpio6_mode”: 4, “gpio7_mode”: 4, “gpio8_mode”: 17, “gpio9_mode”: 17, “max_regen_current”: 0.0, “uart0_protocol”: 3, “uart_a_baudrate”: 9600, “usb_cdc_protocol”: 3, “user_config_0”: 0, “user_config_1”: 0, “user_config_2”: 0, “user_config_3”: 0, “user_config_4”: 0, “user_config_5”: 0, “user_config_6”: 0, “user_config_7”: 0, “brake_resistor0”: {“dc_bus_voltage_feedback_ramp_end”: 53.0, “dc_bus_voltage_feedback_ramp_start”: 51.0, “enable_dc_bus_voltage_feedback”: false, “enable”: true, “resistance”: 2.0}, “gpio11_analog_mapping”: {“endpoint”: null, “max”: 0.0, “min”: 0.0}, “gpio1_analog_mapping”: {“endpoint”: null, “max”: 0.0, “min”: 0.0}, “gpio8_pwm_mapping”: {“endpoint”: null, “max”: 0.0, “min”: 0.0}, “inverter0”: {“current_hard_max”: 96.0, “current_soft_max”: 80.0, “drv_config”: 9029553697166464, “mod_magn_max”: 0.6781481504440308, “shunt_conductance”: 1999.9998779296875, “temp_limit_lower”: 83.95999908447266, “temp_limit_upper”: 103.11000061035156}}, “hall_encoder0”: {“config”: {“edge0”: 0.46867263317108154, “edge1”: 0.6461350321769714, “edge2”: 0.7879056334495544, “edge3”: 0.9674991965293884, “edge4”: 0.15842601656913757, “edge5”: 0.29775094985961914, “edges_calibrated”: true, “enabled”: true, “hall_polarity_calibrated”: true, “hall_polarity”: 0, “ignore_illegal_hall_state”: true}}, “inc_encoder0”: {“config”: {“cpr”: 90, “enabled”: true}}, “rs485_encoder_group0”: {“config”: {“mode”: 0}}, “spi_encoder0”: {“config”: {“baudrate”: 1687500, “biss_c_bits”: 18, “delay”: 0.0, “max_error_rate”: 0.004999999888241291, “mode”: 0, “ncs_gpio”: 17}}, “spi_encoder1”: {“config”: {“baudrate”: 1687500, “biss_c_bits”: 18, “delay”: 0.0, “max_error_rate”: 0.004999999888241291, “mode”: 0, “ncs_gpio”: 17}}}
Pro:
{“amt21_encoder_group0”: {“config”: {“addr0”: 84, “enable”: false, “event_driven_mode”: false, “gpio”: 0, “rs485”: 0}}, “axis0”: {“commutation_mapper”: {“config”: {“approx_init_pos”: 0.0, “approx_init_pos_valid”: false, “circular_output_range”: 1.0, “circular”: true, “index_gpio”: 7, “index_offset”: 0.0, “index_offset_valid”: false, “index_search_always_on”: false, “offset”: 0.0, “offset_valid”: true, “scale”: 1.0, “use_endstop”: false, “use_index_gpio”: false}}, “config”: {“I_bus_hard_max”: Infinity, “I_bus_hard_min”: -Infinity, “calib_range”: 0.019999999552965164, “calib_scan_distance”: 8.0, “calib_scan_vel”: 2.0, “commutation_encoder”: 8, “dir_gpio_pin”: 9, “enable_error_gpio”: false, “enable_step_dir”: false, “enable_watchdog”: false, “encoder_bandwidth”: 100.0, “error_gpio_pin”: 10, “index_search_at_target_vel_only”: false, “load_encoder”: 8, “startup_closed_loop_control”: false, “startup_encoder_index_search”: false, “startup_encoder_offset_calibration”: false, “startup_homing”: false, “startup_max_wait_for_ready”: 3.0, “startup_motor_calibration”: false, “step_dir_always_on”: false, “step_gpio_pin”: 8, “torque_soft_max”: Infinity, “torque_soft_min”: -Infinity, “watchdog_timeout”: 0.0, “anticogging”: {“calib_coarse_integrator_gain”: 100.0, “calib_coarse_tuning_duration”: 60.0, “calib_end_vel”: 0.07000000029802322, “calib_fine_tuning_duration”: 120.0, “calib_start_vel”: 4.0, “enabled”: false, “max_torque”: 0.15000000596046448}, “calibration_lockin”: {“accel”: 3.183098793029785, “current”: 4.0, “ramp_distance”: 0.5, “ramp_time”: 0.4000000059604645, “vel”: 6.36619758605957}, “can”: {“bus_voltage_msg_rate_ms”: 0, “encoder_msg_rate_ms”: 0, “error_msg_rate_ms”: 0, “heartbeat_msg_rate_ms”: 100, “iq_msg_rate_ms”: 0, “is_extended”: false, “node_id”: 3, “temperature_msg_rate_ms”: 0, “torques_msg_rate_ms”: 0, “version_msg_rate_ms”: 0}, “general_lockin”: {“accel”: 20.0, “current”: 10.0, “finish_distance”: 100.0, “finish_on_distance”: false, “finish_on_vel”: false, “initial_pos”: 0.0, “ramp_distance”: 3.1415927410125732, “ramp_time”: 0.4000000059604645, “vel”: 40.0}, “motor”: {“acim_autoflux_attack_gain”: 10.0, “acim_autoflux_decay_gain”: 1.0, “acim_autoflux_enable”: false, “acim_autoflux_min_Id”: 10.0, “acim_gain_min_flux”: 10.0, “acim_nominal_slip_vel”: 2.3399999141693115, “bEMF_FF_enable”: false, “calibration_current”: 4.0, “current_control_bandwidth”: 100.0, “current_hard_max”: 110.0, “current_slew_rate_limit”: 10000.0, “current_soft_max”: 90.0, “direction”: 1.0, “ff_pm_flux_linkage”: 0.0, “ff_pm_flux_linkage_valid”: false, “fw_enable”: false, “fw_fb_bandwidth”: 500.0, “fw_mod_setpoint”: 0.7813565135002136, “motor_model_l_d”: 0.0, “motor_model_l_dq_valid”: false, “motor_model_l_q”: 0.0, “motor_type”: 0, “phase_inductance”: 7.802167965564877e-05, “phase_inductance_valid”: true, “phase_resistance”: 0.08081876486539841, “phase_resistance_valid”: true, “pole_pairs”: 7, “resistance_calib_max_voltage”: 10.0, “sensorless_observer_gain”: 1000.0, “sensorless_pll_bandwidth”: 1000.0, “sensorless_pm_flux_linkage”: 0.0, “sensorless_pm_flux_linkage_valid”: false, “torque_constant”: 0.07876190543174744, “wL_FF_enable”: false}, “sensorless_ramp”: {“accel”: 31.83098793029785, “current”: 10.0, “finish_distance”: 15.915493965148926, “finish_on_distance”: false, “finish_on_vel”: true, “initial_pos”: 0.0, “ramp_distance”: 0.5, “ramp_time”: 0.4000000059604645, “vel”: 63.6619758605957}}, “controller”: {“config”: {“absolute_setpoints”: false, “circular_setpoint_range”: 1.0, “circular_setpoints”: false, “commutation_vel_scale”: 1.0, “control_mode”: 2, “enable_gain_scheduling”: false, “enable_overspeed_error”: true, “enable_torque_mode_vel_limit”: true, “enable_vel_limit”: true, “gain_scheduling_width”: 0.0010000000474974513, “homing_speed”: 0.25, “inertia”: 0.0, “input_filter_bandwidth”: 2.0, “input_mode”: 2, “pos_gain”: 1.0, “spinout_electrical_power_bandwidth”: 20.0, “spinout_electrical_power_threshold”: 10.0, “spinout_mechanical_power_bandwidth”: 20.0, “spinout_mechanical_power_threshold”: -10.0, “steps_per_circular_range”: 1024, “torque_ramp_rate”: 0.009999999776482582, “use_commutation_vel”: false, “vel_gain”: 0.4000000059604645, “vel_integrator_gain”: 2.0, “vel_integrator_limit”: Infinity, “vel_limit”: 40.0, “vel_limit_tolerance”: 1.2000000476837158, “vel_ramp_rate”: 30.0}}, “interpolator”: {“config”: {“dynamic”: true}}, “max_endstop”: {“config”: {“debounce_ms”: 50, “enabled”: false, “gpio_num”: 0, “is_active_high”: false, “offset”: 0.0}}, “mechanical_brake”: {“config”: {“gpio_num”: 0, “is_active_low”: true}}, “min_endstop”: {“config”: {“debounce_ms”: 50, “enabled”: false, “gpio_num”: 0, “is_active_high”: false, “offset”: 0.0}}, “motor”: {“motor_thermistor”: {“config”: {“beta”: 3435.0, “enabled”: true, “gpio_pin”: 3, “r_ref”: 10000.0, “t_ref”: 25.0, “temp_limit_lower”: 100.0, “temp_limit_upper”: 120.0}}}, “pos_vel_mapper”: {“config”: {“approx_init_pos”: 0.0, “approx_init_pos_valid”: false, “circular_output_range”: 1.0, “circular”: false, “index_gpio”: 7, “index_offset”: 0.0, “index_offset_valid”: false, “index_search_always_on”: false, “offset”: 0.0, “offset_valid”: false, “scale”: 0.1428571492433548, “use_endstop”: false, “use_index_gpio”: false}}, “trap_traj”: {“config”: {“accel_limit”: 0.5, “decel_limit”: 0.5, “vel_limit”: 2.0}}}, “can”: {“config”: {“baud_rate”: 250000, “protocol”: 1}}, “config”: {“dc_bus_overvoltage_trip_level”: 52.0, “dc_bus_undervoltage_trip_level”: 10.5, “dc_max_negative_current”: -1.0, “dc_max_positive_current”: 120.0, “enable_can_a”: true, “enable_uart_a”: false, “gpio0_mode”: 17, “gpio10_mode”: 17, “gpio11_mode”: 17, “gpio12_mode”: 4, “gpio13_mode”: 4, “gpio14_mode”: 17, “gpio15_mode”: 17, “gpio16_mode”: 17, “gpio17_mode”: 17, “gpio18_mode”: 17, “gpio1_mode”: 17, “gpio2_mode”: 17, “gpio3_mode”: 17, “gpio4_mode”: 17, “gpio5_mode”: 17, “gpio6_mode”: 17, “gpio7_mode”: 17, “gpio8_mode”: 17, “gpio9_mode”: 17, “max_regen_current”: 0.0, “uart0_protocol”: 3, “uart_a_baudrate”: 115200, “usb_cdc_protocol”: 3, “gpio15_analog_mapping”: {“endpoint”: null, “max”: 0.0, “min”: 0.0}, “gpio16_analog_mapping”: {“endpoint”: null, “max”: 0.0, “min”: 0.0}, “gpio8_pwm_mapping”: {“endpoint”: null, “max”: 0.0, “min”: 0.0}, “gpio9_pwm_mapping”: {“endpoint”: null, “max”: 0.0, “min”: 0.0}, “inverter0”: {“current_hard_max”: 150.0, “current_soft_max”: 100.0, “drv_config”: 9029553772700800, “shunt_conductance”: 1999.9998779296875, “temp_limit_lower”: 83.95999908447266, “temp_limit_upper”: 103.11000061035156}, “motor_fan”: {“enabled”: false, “lower”: 70.0, “upper”: 80.0}, “odrv_fan”: {“enabled”: false, “lower”: 70.0, “upper”: 80.0}}, “hall_encoder0”: {“config”: {“enabled”: true, “hall_polarity_calibrated”: true, “hall_polarity”: 0, “ignore_illegal_hall_state”: true}}, “hall_encoder1”: {“config”: {“enabled”: false, “hall_polarity_calibrated”: false, “hall_polarity”: 0, “ignore_illegal_hall_state”: false}}, “inc_encoder0”: {“config”: {“cpr”: 42, “enabled”: true}}, “inc_encoder1”: {“config”: {“cpr”: 8192, “enabled”: false}}, “spi_encoder0”: {“config”: {“baudrate”: 1687500, “delay”: 0.0, “max_error_rate”: 0.004999999888241291, “mode”: 0, “ncs_gpio”: 17}}, “spi_encoder1”: {“config”: {“baudrate”: 1687500, “delay”: 0.0, “max_error_rate”: 0.004999999888241291, “mode”: 0, “ncs_gpio”: 17}}}
