It looks like over voltage is set to 59.92V. I have a power supply that is 60.1VDC.
Any danger updating firmware to trigger over voltage at 61VDC?
I would also like to know. I have a 14s lipo that has a max voltage of 58.8V and I would like to know if I can run the odrive off it.
Thanks.
Do not exceed the nameplate rating for nominal voltage. If you want to experiment with max voltage, do not exceed 60V, which is the component rating
