Hi!
I met a problem about save_configuration() recently,would you please help me give some suggestion.The details are as follows:
odrv0.axis0.motor.config.pole_pairs = 15
odrv0.axis0.motor.config.requested_current_range = 25
odrv0.axis0.motor.config.torque_constant = 8.27
odrv0.axis0.encoder.config.cpr = 90
odrv0.axis0.encoder.config.bandwidth = 100
odrv0.axis0.controller.config.vel_gain = 0.02 * odrv0.axis0.motor.config.torque_constant * odrv0.axis0.encoder.config.cpr
odrv0.axis0.controller.config.vel_integrator_gain = 0.1 * odrv0.axis0.motor.config.torque_constant * odrv0.axis0.encoder.config.cpr
odrv0.axis0.controller.config.vel_limit = 10
odrv0.save_configuration()
odrv0.reboot()
odrv0.axis0.motor
odrv0.axis0.encoder
All of the above steps are performed OK,motor calibration and encoder calibration successful.
odrv0.reboot()
When i save configuration as above and reboot, All parameters are restored by default.
Is there any problem with my setting?
Thanks for your browsing!!!
