I am having trouble making my Castle Creations 1406- 1900kv sensored motor spin with the odrive v3.6 56V. I contacted the manufacturer and got the following information on this motor:
- pole pairs: 2
- cpr: 12
- sensors: open drain
- power rating: voltage dependent - 180W at 6V
- max. continuous current: 30 amps
I configured the odrive using the values recommended on the website in the hoverboard / hall section. Below I will walk you through the commands I ran and how the motor behaved throughout.
odrv0.axis0.motor.config.current_lim = 20
odrv0.axis0.motor.config.pole_pairs = 2
odrv0.axis0.motor.config.motor_type = MOTOR_TYPE_HIGH_CURRENT`
odrv0.axis0.motor.config.requested_current_range = 25
odrv0.axis0.encoder.config.cpr = 12
odrv0.axis0.encoder.config.bandwidth = 100
odrv0.axis0.controller.config.vel_integrator_gain = 0.1
odrv0.axis0.controller.config.vel_limit = 1000
odrv0.save_configuration()
odrv0.reboot()
Next I calibrated the motor and then had the odrive list out all the data pertaining to the motor. On the website they got the values phase_inductanace = 0.00033 and phase_resistance = 0.17934. Are my values concerning? Could this be my problem?
# the odrive beeped
odrv0.axis0.motor
# phase_inductance = 9.24095
# phase_resistance = 0.03376
Next I calibrated the encoder and the motor spun in both directions which was encouraging. My offset_float value was almost twice as big as what they had on the website, which is offset_float = 0.5126959
# The motor spun in both directions after this command!
odrv0.axis0.encoder
# offset_float = 0.99989
I then saved and rebooted and tried to run the motor using AXIS_STATE_CLOSED_LOOP_CONTROL. The motor did not spin.
odrv0.reboot()
odrv0.axis0.controller.vel_setpoint = 120
# My motor should have spun here but instead did nothing
odrv0.axis0.controller.vel_setpoint = 500
# Still no motion
My motor is quite different from the motors typically used with the odrive. Based on the specs of the motor I listed above, should I be configuring the odrive with different values?
Note: I soldered in 22nF capacitors between the A, B, C and ground pins.
Note: I am using the “odrive control utility v 0.5.1” but have not updated the firmware since buying the odrive. the odrive is a v3.6 and came with v0.4.12 firmware. Could this be my problem?
Any help is greatly appreciated! Thank you!
