Hi!
I am trying to use my ODrive S1 in sensorless mode. I don’t have the exact Kv value of my motor, but I was able to find a value that lets me get pass the ramp-up phase and send speed commands. However, I get the following error frequently and must reboot or change my config to fix it:
active_errors: no error
disarm_reason: Error(s):
ODriveError.SYSTEM_LEVEL
procedure_result: ProcedureResult.DISARMED
last_drv_fault: none
internal issues: none
The error doesn’t show enough details to further debug on my end. From what I see, the error occurs once the motor reach the desired ramp speed. Here’s my config, running on firmware 0.6.9.
odrv0.config.dc_bus_undervoltage_trip_level = 20 # V
odrv0.config.dc_bus_overvoltage_trip_level = 30 # V
odrv0.config.dc_max_positive_current = 50 # A
odrv0.config.dc_max_negative_current = -10 # A
odrv0.axis0.config.motor.pole_pairs = 5
odrv0.axis0.config.motor.torque_constant = 0.01654 # 8.27 / Kv
odrv0.axis0.config.motor.current_soft_max = 80.0 # A
odrv0.axis0.config.motor.current_hard_max = 100.0 # A
odrv0.axis0.controller.config.vel_limit = 100.0 # [turn/s]
odrv0.axis0.config.torque_soft_min = -2 # Nm
odrv0.axis0.config.torque_soft_max = 2 # Nm
odrv0.axis0.config.load_encoder = EncoderId.SENSORLESS_ESTIMATOR
odrv0.axis0.config.commutation_encoder = EncoderId.SENSORLESS_ESTIMATOR
odrv0.axis0.config.sensorless_ramp.vel = -50 # input_vel * pole_pairs [radians/s]
odrv0.axis0.config.sensorless_ramp.accel = 4 # [radians/s^2]
odrv0.axis0.controller.config.control_mode = ControlMode.VELOCITY_CONTROL
Other parameters use the default values. Would appreciate any suggestions to make the error disappear.
Thanks,
William
