Hi all, I’m having some problems getting my motor to calibrate and run with sensorless control.
I’m using a 24V v3.5 ODrive (0.4.7 firmware) with a 5900KV, 4 Pole motor.
The python script that I am using to run the calibration is as follows:
#!/usr/bin/env python3
import odrive
from odrive.enums import *
import time
import math
# Find a connected ODrive (this will block until you connect one)
print("\r\nFinding an ODrive...")
odrv0 = odrive.find_any()
# Erase Current Configuration
# my_drive.erase_configuration()
print("\r\nODrive Found")
print("Bus voltage is:" + str(odrv0.vbus_voltage) + "V")
#print("Calibration current:" + str(odrv0.axis1.motor.config.calibration_current) + "A")
odrv0.config.brake_resistance = 0.5
odrv0.axis1.motor.config.pole_pairs = 2
odrv0.axis1.motor.config.resistance_calib_max_voltage = 5.0
odrv0.axis1.sensorless_estimator.config.pm_flux_linkage = 0.000467228
print("\r\nset parameters\r\n\r\nrequesting calibration")
odrv0.axis1.requested_state = 4
print("phase resistance: ", odrv0.axis1.motor.config.phase_resistance)
time.sleep(5)
print("\r\naxis errors are:")
print(hex(odrv0.axis1.error))
print("motor errors are:")
print(hex(odrv0.axis1.motor.error))
print("encoder errors are:")
print(hex(odrv0.axis1.encoder.error))
print("sensorless estimator errors are:")
print(hex(odrv0.axis1.sensorless_estimator.error))
print("\r\nIs calibrated? ", odrv0.axis1.motor.is_calibrated)
print("")
When I run the script it connects to the ODrive and initializes the calibration. The Odrive draws ~0.2A for a second or two and then returns to it’s idle ~0.05A current draw. It then returns the following information:
ODrive Found
Bus voltage is:11.972973823547363V
set parameters
phase resistance: 0.0
axis errors are:
0x2
motor errors are:
0x0
encoder errors are:
0x0
0x0
Is calibrated? False
Any help or advice in getting this motor to work would be appreciated.
