Hello all,
I am trying to run a sensorless on the DUAL SHAFT MOTOR - D5065 270KV and after the odrv0.axis0.requested_state = AXIS_STATE_SENSORLESS_CONTROL command is entered the motor spins for a second and then stops. When I error dump I run into ERROR_PHASE_RESISTANCE_OUT_OF_RANGE. Would one of these commands work to fix this?odrv0.axis0.motor.config.resistance_calib_max_voltage odrv0.axis0.motor.config.requested_current_range
odrv0.axis0.motor.config.calibration_current
Thanks all!
