Setpoint-command doesnt work - Fixed
Hi all!
I set up my new odrive (3.5, 48V) according to the chapter “getting started”.
I came to the calibration sequence which worked very well.
But I wasnt able to turn the Motor with an “odrv0.axis0.controller.pos_setpoint = 8000” command.
No errors at all. Double-checked everything - wiring, power source, parameters…nothing.
What can I try???
Peter W.
Hi Wickie,
did you enable closed loop?
Otherwise ODrive will not react to your commands.
Greetings / Zennix
Hi Zennix!
Thanks a lot for your support!
Good Idea! I will try it as soon as my Odrive is allive again
Regards
Peter
Hi Zennix!
I tried your proposal today and the Setpoint commands are working now !!! Again thank you verry much !!
gretings
Peter
