I’m currently building a four wheel drive electric longboard for a thesis and can’t get the Torque Control to work at all. No errors occur, there’s just no movement at all. I got everything set up on a test bench so the motors can spin freely. I followed the steps in the instruction but seem to be missing something major. Velocity Control works fine via CAN with the integrated hall sensors of the motors. If anyone can help me I’d appreciate it very much.
This is my config for the ODrive v3.6 56V:
Controller:
config:
anticogging: …
axis_to_mirror: 255 (uint8)
control_mode: 1 (uint8)
electrical_power_bandwidth: 20.0 (float)
enable_torque_mode_vel_limit: True (bool)
enable_vel_limit: True (bool)
homing_speed: 0.25 (float)
inertia: 0.0 (float)
input_mode: 2 (uint8)
load_encoder_axis: 0 (uint8)
mechanical_power_bandwidth: 20.0 (float)
mirror_ratio: 1.0 (float)
pos_gain: 1.0 (float)
spinout_electrical_power_threshold: 10.0 (float)
spinout_mechanical_power_threshold: -10.0 (float)
steps_per_circular_range: 1024 (int32)
torque_mirror_ratio: 0.0 (float)
torque_ramp_rate: 0.009999999776482582 (float)
vel_gain: 0.23155999183654785 (float)
vel_integrator_gain: 1.1577999591827393 (float)
vel_integrator_limit: inf (float)
vel_limit: 20.0 (float)
vel_limit_tolerance: 1.2000000476837158 (float)
vel_ramp_rate: 2.0 (float)
electrical_power: -0.0412989966571331 (float)
error: 0 (uint8)
input_pos: 0.0 (float)
input_torque: 1.0 (float)
input_vel: 0.0 (float)
last_error_time: 0.0 (float)
mechanical_power: 0.0 (float)
move_incremental(obj: object_ref, displacement: float, from_input_pos: bool)
pos_setpoint: 0.0 (float)
start_anticogging_calibration(obj: object_ref)
torque_setpoint: 0.0 (float)
trajectory_done: True (bool)
vel_integrator_torque: 0.0 (float)
vel_setpoint: 0.0 (float)
Motor:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
current_lim: 10.0 (float)
motor_type: 0 (uint8)
phase_inductance: 0.00014396579354070127 (float)
phase_resistance: 0.5408436059951782 (float)
pole_pairs: 14 (int32)
pre_calibrated: True (bool)
requested_current_range: 25.0 (float)
resistance_calib_max_voltage: 15.0 (float)
torque_constant: 0.13783332705497742 (float)
torque_lim: inf (float)
Encoder:
abs_spi_cs_gpio_pin: 1 (uint16)
calib_scan_distance: 150.0 (float)
cpr: 84 (int32)
direction: -1 (int32)
find_idx_on_lockin_only: False (bool)
hall_polarity: 0 (uint8)
hall_polarity_calibrated: True (bool)
index_offset: 0.0 (float)
mode: 1 (uint16)
phase_offset: 9 (int32)
phase_offset_float: 1.4050372838974 (float)
use_index: False (bool)
use_index_offset: True (bool)
Axis:
calibration_lockin:
accel: 20.0 (float)
ramp_distance: 3.1415927410125732 (float)
ramp_time: 0.4000000059604645 (float)
vel: 40.0 (float)
can:
encoder_rate_ms: 10 (uint32)
heartbeat_rate_ms: 100 (uint32)
is_extended: False (bool)
node_id: 0 (uint32)
dir_gpio_pin: 2 (uint16)
enable_sensorless_mode: False (bool)
enable_step_dir: False (bool)
enable_watchdog: False (bool)
general_lockin:
accel: 20.0 (float)
finish_distance: 100.0 (float)
finish_on_distance: False (bool)
finish_on_enc_idx: False (bool)
finish_on_vel: False (bool)
vel: 40.0 (float)
sensorless_ramp:
accel: 200.0 (float)
finish_on_vel: True (bool)
vel: 400.0 (float)
startup_closed_loop_control: False (bool)
startup_encoder_index_search: False (bool)
startup_encoder_offset_calibration: False (bool)
startup_homing: False (bool)
startup_motor_calibration: False (bool)
step_dir_always_on: False (bool)
step_gpio_pin: 1 (uint16)
watchdog_timeout: 0.0 (float)
