In this very helpful post @madcowswe gives a link to suitable resistors but the link is dead, @rowanG on another helpful post linked an alternative, but that link is also dead ![]()
Can someone please spell out the proper packaging and wattage for the odrv3.6 shunt resistors?
Which resistance do you want and why do you want to replace shunts?
My motor’s max current is 9A, looking for ~12A range, reasons are better current regulating resolution and less noise, you can have more context on the linked thread from my original post.
I’ll be using a 0.01 Ohm resistor I found at digikey wich is about the same size 3mm wide 6.5mm long.
