Software "Limited Slip" Differential
I am planing to use an Odrive in an electric Gokart with one motor for each wheel on the rear axis.
My question is: What would be the best way to get the effect of an (adjustable) limited slip differential?
I would suggest using the velocity limited torque mode, and use some central controller to continuously set the velocity limit of an axis to some margin on top of the measured velocity of the other axis.
