I just ended up the “getting tarted” guide.
But when I follow the procedure to bypass encoder calibration " Encoder with index signal" I have some error .
From my tests axis error seems to come from the <axis>.requested_state = AXIS_STATE_ENCODER_INDEX_SEARCH
as you can see here :
In [1]: odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
In [2]: odrv0.axis0.error
Out[2]: 0
In [3]: odrv0.axis0.encoder.config.offset
Out[3]: 8516
In [4]: odrv0.axis0.encoder.config.use_index=True
In [5]: odrv0.axis0.requested_state = AXIS_STATE_ENCODER_INDEX_SEARCH
In [6]: odrv0.axis0.requested_state = AXIS_STATE_ENCODER_OFFSET_CALIBRATION
In [7]: odrv0.axis0.error
Out[7]: 352
In [8]: odrv0.axis0.encoder.config.offset
Out[8]: 8516
I notice , that compare to the full calibration sequence, the encoder index search is go very very fast .
I tried to reduce the calibration_current but it doen’t helped.
I also notice EACH time I ran the encoder search index command the Odrive disangage the motor, and no command respond . I have to reboot .
Btw it’s the same if I force by hand the motor shaft in close_loop control or other situations.
Connected to ODrive 2064396C4D4D as odrv0
Out[2]: 0
In [3]: dump_errors(odrv0)
axis: no error
motor: no error
axis1
axis: no error
motor: no error
In [6]: odrv0.axis0.error
Out[6]: 96
In [7]: dump_errors(odrv0)
axis: Error(s):
ERROR_MOTOR_DISARMED
ERROR_MOTOR_FAILED
motor: Error(s):
ERROR_CURRENT_UNSTABLE
axis1
axis: no error
motor: no error
Does odrv0.axis0.requested_state = AXIS_STATE_ENCODER_INDEX_SEARCH need odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL before it ? or any other command ?
Finally solve my probleme after reading again and again the “getting started” page.
My motor is not a GIMBAL one but try it solve the issue shown by:
Out[2]: 0
or
axis: Error(s):
ERROR_MOTOR_FAILED
motor: Error(s):
As you can see:
In [2]: odrv0.axis0.motor.config.motor_type=MOTOR_TYPE_GIMBAL
axis: no error
motor: no error
axis1
axis: no error
motor: no error
In [6]: dump_errors(odrv0)
axis: no error
motor: no error
axis1
axis: no error
motor: no error
In [7]: odrv0.axis0.motor.config.phase_resistance
Out[7]: 0.40172049403190613
In [8]: odrv0.axis0.motor.config.phase_inductance
Out[8]: 0.00036134623223915696
Btw , I’m very noob about code, I can’t find where I saw somewhere a python command to make the motor going to a point then back to it’s original position then to the point… infinitly in only one command. It was looking from far to something like odrv0.axis0.controller.pos=(xxx,y)
If you see what I mean it could be very helpful for my real tests and tuning
