Hello
I have been using a ODrive v3.6-24v for awhile with the ODrive Tool v4.12, and recently i upgraded to v5.1, and now through the terminal, i get errors such as “object has no attribute”. I have been using “current control” up until now, and this control mode has been replaced by “torque control”. In my python scripts, i had to change a few things (such as CTRL_MODE… -> CONTROL_MODE…).
The main issue is that (following the “getting started” wiki page), when i try to access the torque control mode, the object odrv0.axis0.motor.config doesn’t have the attribute “torque_constant”. The method odrv0.axis0.controller.input_torque doesn’t exist either.
Do i need to modify the firmware / re-upload a newer version?
Thank you.
