I have been trying for the last few days to get my odrive 3.6-56v board running, I am using an AS5047U SPI encoder, but I cant get it to work properly with ODrive.
I have followed all the steps, however I always get an ENCODER_ERROR_ABS_SPI_COM_FAIL
I have tested the encoder on SPI with an arduino, and also get clean data from odrv0.axis0.encoder.shadow_count so it is working fine. Once I set all the settings and save I get no errors from dump_errors(odrv0) however once I reboot then I get the following.
In [**69**]: dump_errors(odrv0)
axis: **Error(s):**
AXIS_ERROR_ENCODER_FAILED
motor: **no error**
fet_thermistor: **no error**
motor_thermistor: **no error**
encoder: **Error(s):**
controller: **no error**
I also get an error rate of around 0.5, which I believe should be 0. Any help would be massively appreciated!
In [**52**]: odrv0.axis0.encoder.shadow_count
Out[**52**]: 349
In [**53**]: odrv0.axis0.encoder.shadow_count
Out[**53**]: 347
In [**54**]: odrv0.axis0.encoder.shadow_count
Out[**54**]: 349
In [**55**]: odrv0.axis0.encoder.shadow_count
Out[**55**]: 349
In [**56**]: odrv0.axis0.encoder.shadow_count
Out[**56**]: 350
In [**57**]: odrv0.axis0.encoder.shadow_count
Out[**57**]: -9167
In [**58**]: odrv0.axis0.encoder.shadow_count
Out[**58**]: -56215
In [**38**]: odrv0.axis0.encoder.spi_error_rate
Out[**38**]: 0.5484153628349304
In [**39**]: odrv0.axis0.encoder.spi_error_rate
Out[**39**]: 0.47363629937171936
In [**40**]: odrv0.axis0.encoder.spi_error_rate
Out[**40**]: 0.4634641110897064
In [**41**]: odrv0.axis0.encoder.spi_error_rate
Out[**41**]: 0.4897249639034271
