Is there any way to control the motors into closed-loop velocity mode without the need to have a calibration setup on every startup that would need to turn the motors. I’m asking because I would like to use hub motors with build-in optical encoder (without an index) for a mobile autonomous robot and I can’t move the robot on every startup just for encoder calibration.
I have seen a discussion about using hal sensor as an make-shift index HAL + Encoder mixed mode , but that seems not to be implemented at current moment.
