Strange behaviour when both axis start
#1
Hi!.
I started to setup the hoverboard example.
All is fine until i try to start both axis like this:
odrv0.axis0.controller.vel_setpoint = 120
odrv0.axis1.controller.vel_setpoint = 120
It worked once. But most of the time axis0 turns off when axis1 turns on and vice versa.
The part with the RF receiver has the same behaviour. I cannot start both axis at the same time. It is one or the other.
Can someone please give me some advice? Have you encountered this issue before?
Thanks
#2
Have you solder capacitors to encoder Odrive inputs?
#3
No. I did not!
But in this case i was expecting an encoder error . I will add some caps and post an update. Thanks
#4
I fact I also have same issue after capacitors were solder
