Struggling connecting odrives via can
I’ve wired up my odrives in a chain to the usb can adapter but only the 2nd and 4th board are communicating to my PC through the adapter. I linked the image of the wiring, if anyone has time to take a look. Thanks
Hi. I’ve just started learning CAN also. The 2 important things for me were 1. The first and last devices should have the 120 ohm resistor switch on. The others should be off. I just had 2 S1s and the CAN adapter. So I switched the CAN resistor on, the S1 connected to the adapter was off and the second S1 which was connected to the first S1 had its resistor on.
2. Was following the grounding diagram: CAN Bus Guide — ODrive Documentation 0.6.12 documentation
You could also try with the adapter and one S1. If that works, add another S1.
HTH. I bet solomon will be by shortly to fix anything I got wrong.
Hi :slight_smile: looks like you’re swapping the pinout between each set of wires?
Should be 1-1 / 2-2 / 3-3 / 4-4 for each connector, like this:
@solomondg Hi. Thanks for taking a look. It does appear that way, but for the last in the chain, I had to use a red in position 1 because it was the only wire I had at the time. So the red effectively takes the role of the green for the output of the 3rd odrive, and it follows into position 1 in the last driver.
Am i making sense here or am i missing something? Thanks again for your patience!
Will give this a try when I get the chance, Thanks!
Ah, gotcha – yes the colored arrows help :slight_smile: I have seen this exact two/four working but one/three drop out, or vice versa issue caused by the wire pair swaps between each drive. So I’m definitely still a little suspicious, but I agree that after staring at this for a while, it does seem like it’s pretty correct. Interesting.
Also, like Ron said, run a wire from the adapter’s GND screw terminal to DC- at your supply (if you don’t have a tie somewhere else on your system). The GND pin on the S1’s CAN connector is only a passthrough.
Are you trying to connect over ODrivetool/the GUI, or are you directly talking CAN yourself?
