Struggling with Hoover Motors to run - Error at The "Closed_loop_Control"
Everything went well with the configuration from top to bottom without any errors in dump_errors(odrv0, True) But when I am trying to test RUN it then got the error. @towen
I am running 2 Hoover motors on a 40v 5Ah battery.
In [67]: odrv0.axis1.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
In [68]: odrv0.axis1.controller.input_vel = 1
In [69]: dump_errors(odrv0, True)
system: Error(s):
ODRIVE_ERROR_DC_BUS_OVER_REGEN_CURRENT
axis: no error
motor: Error(s):
MOTOR_ERROR_SYSTEM_LEVEL
axis1
axis: no error
motor: Error(s):
odrv0.save_configuration()
These two lines of configuration saved my day.
