I have an odrive which I can connect to using odrivetool on my laptop, but I cannot connect to it with a totally freshly configured raspberry pi 4.
I’ve taken the latest raspbian lite image and flashed it on to an sd card. I enabled ssh and setup wifi using a known good wpa_supplicant.conf. I changed the hostname. I powered it on and ssh’d in. I did a sudo apt update and sudo apt upgrade and rebooted. Then I did sudo apt install python3-pip and sudo pip3 install odrive. Then I rebooted. That is all I have done with this pi image.
Then I log back in, run sudo odrivetool -v, and get the following:
ODrive control utility v0.4.11
Waiting for ODrive...
USB discover loop
ConfigurationValue 1
InterfaceNumber 0,0
EndpointAddress 130
InterfaceNumber 1,0
EndpointAddress 1
EndpointAddress 129
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
Kernel Driver was not attached
EndpointAddress for writing 3
EndpointAddress for reading 131
Connecting to device on USB device bus 1 device 4
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:104: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('import sys')
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:105: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('superexcepthook = sys.excepthook')
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:106: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('def newexcepthook(ex_class,ex,trace):\n'
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:109: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('sys.excepthook=newexcepthook')
Please connect your ODrive.
Now I’ve seen those warnings on other systems that still work, so I’m less concerned there. I have waited several minutes because I know sometimes connecting is slow. But it never connects. I have power cycled and tried multiple times. However my laptop connects with success (see below).
I should say that reflashing the Pi4 came after a day of bad luck yesterday trying to get this odrive I have to connect. Neither my desktop (new install of the pip3 package) nor my raspberry pi (also a new install of the pip3 package) would connect to the odrive, and I thought it was dead until I realized my laptop will connect to it just fine. I have another system of odrives and a raspberry pi that previously worked, and yesterday I had trouble with it too.
So I’m going a little nuts. I can’t work on my robot until I can get a pi to connect again. Is the current pip package actually working?
I do get a weird thing with my laptop, which is this JSON error others on this board have seen. Here is what a successful connection looks like on my laptop right now:
ODrive control utility v0.4.11.dev
Developer Preview
If you find issues, please report them
on https://github.com/madcowswe/ODrive/issues
or better yet, submit a pull request to fix it.
USB discover loop
InterfaceNumber 0,0
EndpointAddress 130
InterfaceNumber 1,0
EndpointAddress 1
EndpointAddress 129
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
Connecting to device on USB device bus 1 device 29
JSON: [
{"name":"","id":0,"type":"json","access":"r"},
{"name":"vbus_voltage","id":1,"type":"float","access":"r"},
{"name":"serial_number","id":2,"type":"uint64","access":"r"},
{"name":"hw_version_major","id":3,"type":"uint8","access":"r"},
{"name":"hw_version_minor","id":4,"type":"uint8","access":"r"},
{"name":"hw_version_variant","id":5,"type":"uint8","access":"r"},
{"name":"fw_version_major","id":6,"type":"uint8","access":"r"},
{"name":"fw_version_minor","id":7,"type":"uint8","access":"r"},
{"name":"fw_version_revision","id":8,"type":"uint8","access":"r"},
{"name":"fw_version_unreleased","id":9,"type":"uint8","access":"r"},
{"name":"user_config_loaded","id":10,"type":"bool","access":"r"},
{"name":"brake_resistor_armed","id":11,"type":"bool","access":"r"},
{"name":"system_stats","type":"object","members":[
{"name":"uptime","id":12,"type":"uint32","access":"r"},
{"name":"min_heap_space","id":13,"type":"uint32","access":"r"},
{"name":"min_stack_space_axis0","id":14,"type":"uint32","access":"r"},
{"name":"min_stack_space_axis1","id":15,"type":"uint32","access":"r"},
{"name":"min_stack_space_comms","id":16,"type":"uint32","access":"r"},
{"name":"min_stack_space_usb","id":17,"type":"uint32","access":"r"},
{"name":"min_stack_space_uart","id":18,"type":"uint32","access":"r"},
{"name":"min_stack_space_usb_irq","id":19,"type":"uint32","access":"r"},
{"name":"min_stack_space_startup","id":20,"type":"uint32","access":"r"},
{"name":"usb","type":"object","members":[
{"name":"rx_cnt","id":21,"type":"uint32","access":"r"},
{"name":"tx_cnt","id":22,"type":"uint32","access":"r"},
{"name":"tx_overrun_cnt","id":23,"type":"uint32","access":"r"}]},
{"name":"i2c","type":"object","members":[
{"name":"addr","id":24,"type":"uint8","access":"r"},
{"name":"addr_match_cnt","id":25,"type":"uint32","access":"r"},
{"name":"rx_cnt","id":26,"type":"uint32","access":"r"},
{"name":"error_cnt","id":27,"type":"uint32","access":"r"}]}]},
{"name":"config","type":"object","members":[
{"name":"brake_resistance","id":28,"type":"float","access":"rw"},
{"name":"enable_uart","id":29,"type":"bool","access":"rw"},
{"name":"enable_i2c_instead_of_can","id":30,"type":"bool","access":"rw"},
{"name":"enable_ascii_protocol_on_usb","id":31,"type":"bool","access":"rw"},
{"name":"dc_bus_undervoltage_trip_level","id":32,"type":"float","access":"rw"},
{"name":"dc_bus_overvoltage_trip_level","id":33,"type":"float","access":"rw"},
{"name":"gpio1_pwm_mapping","type":"object","members":[
{"name":"endpoint","id":34,"type":"endpoint_ref","access":"rw"},
{"name":"min","id":35,"type":"float","access":"rw"},
{"name":"max","id":36,"type":"float","access":"rw"}]},
{"name":"gpio2_pwm_mapping","type":"object","members":[
{"name":"endpoint","id":37,"type":"endpoint_ref","access":"rw"},
{"name":"min","id":38,"type":"float","access":"rw"},
{"name":"max","id":39,"type":"float","access":"rw"}]},
{"name":"gpio3_pwm_mapping","type":"object","members":[
{"name":"endpoint","id":40,"type":"endpoint_ref","access":"rw"},
{"name":"min","id":41,"type":"float","access":"rw"},
{"name":"max","id":42,"type":"float","access":"rw"}]},
{"name":"gpio4_pwm_mapping","type":"object","members":[
{"name":"endpoint","id":43,"type":"endpoint_ref","access":"rw"},
{"name":"min","id":44,"type":"float","access":"rw"},
{"name":"max","id":45,"type":"float","access":"rw"}]},
{"name":"gpio3_analog_mapping","type":"object","members":[
{"name":"endpoint","id":46,"type":"endpoint_ref","access":"rw"},
{"name":"min","id":47,"type":"float","access":"rw"},
{"name":"max","id":48,"type":"float","access":"rw"}]},
{"name":"gpio4_analog_mapping","type":"object","members":[
{"name":"endpoint","id":49,"type":"endpoint_ref","access":"rw"},
{"name":"min","id":50,"type":"float","access":"rw"},
{"name":"max","id":51,"type":"float","access":"rw"}]}]},
{"name":"axis0","type":"object","members":[
{"name":"error","id":52,"type":"uint16","access":"rw"},
{"name":"step_dir_active","id":53,"type":"bool","access":"r"},
{"name":"current_state","id":54,"type":"uint8","access":"r"},
{"name":"requested_state","id":55,"type":"uint8","access":"rw"},
{"name":"loop_counter","id":56,"type":"uint32","access":"r"},
{"name":"lockin_state","id":57,"type":"uint8","access":"r"},
{"name":"startup_motor_calibration","id":58,"type":"bool","access":"rw"},
{"name":"startup_encoder_index_search","id":59,"type":"bool","access":"rw"},
{"name":"startup_encoder_offset_calibration","id":60,"type":"bool","access":"rw"},
{"name":"startup_closed_loop_control","id":61,"type":"bool","access":"rw"},
{"name":"startup_sensorless_control","id":62,"type":"bool","access":"rw"},
{"name":"enable_step_dir","id":63,"type":"bool","access":"rw"},
{"name":"counts_per_step","id":64,"type":"float","access":"rw"},
{"name":"watchdog_timeout","id":65,"type":"float","access":"rw"},
{"name":"step_gpio_pin","id":66,"type":"uint16","access":"rw"},
{"name":"dir_gpio_pin","id":67,"type":"uint16","access":"rw"},
{"name":"lockin","type":"object","members":[
{"name":"current","id":68,"type":"float","access":"rw"},
{"name":"ramp_time","id":69,"type":"float","access":"rw"},
{"name":"ramp_distance","id":70,"type":"float","access":"rw"},
{"name":"accel","id":71,"type":"float","access":"rw"},
{"name":"vel","id":72,"type":"float","access":"rw"},
{"name":"finish_distance","id":73,"type":"float","access":"rw"},
{"name":"finish_on_vel","id":74,"type":"bool","access":"rw"},
{"name":"finish_on_distance","id":75,"type":"bool","access":"rw"},
{"name":"finish_on_enc_idx","id":76,"type":"bool","access":"rw"}]}]},
{"name":"motor","type":"object","members":[
{"name":"error","id":77,"type":"uint16","access":"rw"},
{"name":"armed_state","id":78,"type":"uint8","access":"r"},
{"name":"is_calibrated","id":79,"type":"bool","access":"r"},
{"name":"current_meas_phB","id":80,"type":"float","access":"r"},
{"name":"current_meas_phC","id":81,"type":"float","access":"r"},
{"name":"DC_calib_phB","id":82,"type":"float","access":"rw"},
{"name":"DC_calib_phC","id":83,"type":"float","access":"rw"},
{"name":"phase_current_rev_gain","id":84,"type":"float","access":"rw"},
{"name":"thermal_current_lim","id":85,"type":"float","access":"r"},
{"name":"get_inverter_temp","id":86,"type":"function","inputs":[],"outputs":[
{"name":"result","id":87,"type":"float","access":"rw"}]},
{"name":"current_control","type":"object","members":[
{"name":"p_gain","id":88,"type":"float","access":"rw"},
{"name":"i_gain","id":89,"type":"float","access":"rw"},
{"name":"v_current_control_integral_d","id":90,"type":"float","access":"rw"},
{"name":"v_current_control_integral_q","id":91,"type":"float","access":"rw"},
{"name":"Ibus","id":92,"type":"float","access":"rw"},
{"name":"final_v_alpha","id":93,"type":"float","access":"rw"},
{"name":"final_v_beta","id":94,"type":"float","access":"rw"},
{"name":"Iq_setpoint","id":95,"type":"float","access":"rw"},
{"name":"Iq_measured","id":96,"type":"float","access":"rw"},
{"name":"Id_measured","id":97,"type":"float","access":"rw"},
{"name":"I_measured_report_filter_k","id":98,"type":"float","access":"rw"},
{"name":"max_allowed_current","id":99,"type":"float","access":"r"},
{"name":"overcurrent_trip_level","id":100,"type":"float","access":"r"}]},
{"name":"gate_driver","type":"object","members":[
{"name":"drv_fault","id":101,"type":"uint16","access":"r"}]},
{"name":"timing_log","type":"object","members":[
{"name":"TIMING_LOG_GENERAL","id":102,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_ADC_CB_I","id":103,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_ADC_CB_DC","id":104,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_MEAS_R","id":105,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_MEAS_L","id":106,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_ENC_CALIB","id":107,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_IDX_SEARCH","id":108,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_FOC_VOLTAGE","id":109,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_FOC_CURRENT","id":110,"type":"uint16","access":"r"}]},
{"name":"pre_calibrated","id":111,"type":"bool","access":"rw"},
{"name":"pole_pairs","id":112,"type":"int32","access":"rw"},
{"name":"calibration_current","id":113,"type":"float","access":"rw"},
{"name":"resistance_calib_max_voltage","id":114,"type":"float","access":"rw"},
{"name":"phase_inductance","id":115,"type":"float","access":"rw"},
{"name":"phase_resistance","id":116,"type":"float","access":"rw"},
{"name":"direction","id":117,"type":"int32","access":"rw"},
{"name":"motor_type","id":118,"type":"uint8","access":"rw"},
{"name":"current_lim","id":119,"type":"float","access":"rw"},
{"name":"inverter_temp_limit_lower","id":120,"type":"float","access":"rw"},
{"name":"inverter_temp_limit_upper","id":121,"type":"float","access":"rw"},
{"name":"requested_current_range","id":122,"type":"float","access":"rw"},
{"name":"current_control_bandwidth","id":123,"type":"float","access":"rw"}]}]},
{"name":"controller","type":"object","members":[
{"name":"error","id":124,"type":"uint8","access":"rw"},
{"name":"pos_setpoint","id":125,"type":"float","access":"rw"},
{"name":"vel_setpoint","id":126,"type":"float","access":"rw"},
{"name":"vel_integrator_current","id":127,"type":"float","access":"rw"},
{"name":"current_setpoint","id":128,"type":"float","access":"rw"},
{"name":"vel_ramp_target","id":129,"type":"float","access":"rw"},
{"name":"vel_ramp_enable","id":130,"type":"bool","access":"rw"},
{"name":"control_mode","id":131,"type":"uint8","access":"rw"},
{"name":"pos_gain","id":132,"type":"float","access":"rw"},
{"name":"vel_gain","id":133,"type":"float","access":"rw"},
{"name":"vel_integrator_gain","id":134,"type":"float","access":"rw"},
{"name":"vel_limit","id":135,"type":"float","access":"rw"},
{"name":"vel_limit_tolerance","id":136,"type":"float","access":"rw"},
{"name":"vel_ramp_rate","id":137,"type":"float","access":"rw"},
{"name":"setpoints_in_cpr","id":138,"type":"bool","access":"rw"}]},
{"name":"set_pos_setpoint","id":139,"type":"function","inputs":[
{"name":"pos_setpoint","id":140,"type":"float","access":"rw"},
{"name":"vel_feed_forward","id":141,"type":"float","access":"rw"},
{"name":"current_feed_forward","id":142,"type":"float","access":"rw"}],"outputs":[]},
{"name":"set_vel_setpoint","id":143,"type":"function","inputs":[
{"name":"vel_setpoint","id":144,"type":"float","access":"rw"},
{"name":"current_feed_forward","id":145,"type":"float","access":"rw"}],"outputs":[]},
{"name":"set_current_setpoint","id":146,"type":"function","inputs":[
{"name":"current_setpoint","id":147,"type":"float","access":"rw"}],"outputs":[]},
{"name":"move_to_pos","id":148,"type":"function","inputs":[
{"name":"pos_setpoint","id":149,"type":"float","access":"rw"}],"outputs":[]},
{"name":"move_incremental","id":150,"type":"function","inputs":[
{"name":"displacement","id":151,"type":"float","access":"rw"},
{"name":"from_goal_point","id":152,"type":"bool","access":"rw"}],"outputs":[]},
{"name":"start_anticogging_calibration","id":153,"type":"function","inputs":[],"outputs":[]}]},
{"name":"encoder","type":"object","members":[
{"name":"error","id":154,"type":"uint8","access":"rw"},
{"name":"is_ready","id":155,"type":"bool","access":"rw"},
{"name":"index_found","id":156,"type":"bool","access":"rw"},
{"name":"shadow_count","id":157,"type":"int32","access":"rw"},
{"name":"count_in_cpr","id":158,"type":"int32","access":"rw"},
{"name":"interpolation","id":159,"type":"float","access":"rw"},
{"name":"phase","id":160,"type":"float","access":"r"},
{"name":"pos_estimate","id":161,"type":"float","access":"rw"},
{"name":"pos_cpr","id":162,"type":"float","access":"rw"},
{"name":"hall_state","id":163,"type":"uint8","access":"r"},
{"name":"vel_estimate","id":164,"type":"float","access":"rw"},
{"name":"calib_scan_response","id":165,"type":"float","access":"r"},
{"name":"mode","id":166,"type":"uint8","access":"rw"},
{"name":"use_index","id":167,"type":"bool","access":"rw"},
{"name":"find_idx_on_lockin_only","id":168,"type":"bool","access":"rw"},
{"name":"pre_calibrated","id":169,"type":"bool","access":"rw"},
{"name":"zero_count_on_find_idx","id":170,"type":"bool","access":"rw"},
{"name":"cpr","id":171,"type":"int32","access":"rw"},
{"name":"offset","id":172,"type":"int32","access":"rw"},
{"name":"offset_float","id":173,"type":"float","access":"rw"},
{"name":"enable_phase_interpolation","id":174,"type":"bool","access":"rw"},
{"name":"bandwidth","id":175,"type":"float","access":"rw"},
{"name":"calib_range","id":176,"type":"float","access":"rw"},
{"name":"calib_scan_distance","id":177,"type":"float","access":"rw"},
{"name":"calib_scan_omega","id":178,"type":"float","access":"rw"},
{"name":"idx_search_unidirectional","id":179,"type":"bool","access":"rw"},
{"name":"ignore_illegal_hall_state","id":180,"type":"bool","access":"rw"}]},
{"name":"set_linear_count","id":181,"type":"function","inputs":[
{"name":"count","id":182,"type":"int32","access":"rw"}],"outputs":[]}]},
{"name":"sensorless_estimator","type":"object","members":[
{"name":"error","id":183,"type":"uint8","access":"rw"},
{"name":"phase","id":184,"type":"float","access":"rw"},
{"name":"pll_pos","id":185,"type":"float","access":"rw"},
{"name":"vel_estimate","id":186,"type":"float","access":"rw"},
{"name":"observer_gain","id":187,"type":"float","access":"rw"},
{"name":"pll_bandwidth","id":188,"type":"float","access":"rw"},
{"name":"pm_flux_linkage","id":189,"type":"float","access":"rw"}]}]},
{"name":"trap_traj","type":"object","members":[
{"name":"vel_limit","id":190,"type":"float","access":"rw"},
{"name":"accel_limit","id":191,"type":"float","access":"rw"},
{"name":"decel_limit","id":192,"type":"float","access":"rw"},
{"name":"A_per_css","id":193,"type":"float","access":"rw"}]}]},
{"name":"watchdog_feed","id":194,"type":"function","inputs":[],"outputs":[]}]},
{"name":"axis1","type":"object","members":[
{"name":"error","id":195,"type":"uint16","access":"rw"},
{"name":"step_dir_active","id":196,"type":"bool","access":"r"},
{"name":"current_state","id":197,"type":"uint8","access":"r"},
{"name":"requested_state","id":198,"type":"uint8","access":"rw"},
{"name":"loop_counter","id":199,"type":"uint32","access":"r"},
{"name":"lockin_state","id":200,"type":"uint8","access":"r"},
{"name":"startup_motor_calibration","id":201,"type":"bool","access":"rw"},
{"name":"startup_encoder_index_search","id":202,"type":"bool","access":"rw"},
{"name":"startup_encoder_offset_calibration","id":203,"type":"bool","access":"rw"},
{"name":"startup_closed_loop_control","id":204,"type":"bool","access":"rw"},
{"name":"startup_sensorless_control","id":205,"type":"bool","access":"rw"},
{"name":"enable_step_dir","id":206,"type":"bool","access":"rw"},
{"name":"counts_per_step","id":207,"type":"float","access":"rw"},
{"name":"watchdog_timeout","id":208,"type":"float","access":"rw"},
{"name":"step_gpio_pin","id":209,"type":"uint16","access":"rw"},
{"name":"dir_gpio_pin","id":210,"type":"uint16","access":"rw"},
{"name":"current","id":211,"type":"float","access":"rw"},
{"name":"ramp_time","id":212,"type":"float","access":"rw"},
{"name":"ramp_distance","id":213,"type":"float","access":"rw"},
{"name":"accel","id":214,"type":"float","access":"rw"},
{"name":"vel","id":215,"type":"float","access":"rw"},
{"name":"finish_distance","id":216,"type":"float","access":"rw"},
{"name":"finish_on_vel","id":217,"type":"bool","access":"rw"},
{"name":"finish_on_distance","id":218,"type":"bool","access":"rw"},
{"name":"finish_on_enc_idx","id":219,"type":"bool","access":"rw"}]}]},
{"name":"error","id":220,"type":"uint16","access":"rw"},
{"name":"armed_state","id":221,"type":"uint8","access":"r"},
{"name":"is_calibrated","id":222,"type":"bool","access":"r"},
{"name":"current_meas_phB","id":223,"type":"float","access":"r"},
{"name":"current_meas_phC","id":224,"type":"float","access":"r"},
{"name":"DC_calib_phB","id":225,"type":"float","access":"rw"},
{"name":"DC_calib_phC","id":226,"type":"float","access":"rw"},
{"name":"phase_current_rev_gain","id":227,"type":"float","access":"rw"},
{"name":"thermal_current_lim","id":228,"type":"float","access":"r"},
{"name":"get_inverter_temp","id":229,"type":"function","inputs":[],"outputs":[
{"name":"result","id":230,"type":"float","access":"rw"}]},
{"name":"p_gain","id":231,"type":"float","access":"rw"},
{"name":"i_gain","id":232,"type":"float","access":"rw"},
{"name":"v_current_control_integral_d","id":233,"type":"float","access":"rw"},
{"name":"v_current_control_integral_q","id":234,"type":"float","access":"rw"},
{"name":"Ibus","id":235,"type":"float","access":"rw"},
{"name":"final_v_alpha","id":236,"type":"float","access":"rw"},
{"name":"final_v_beta","id":237,"type":"float","access":"rw"},
{"name":"Iq_setpoint","id":238,"type":"float","access":"rw"},
{"name":"Iq_measured","id":239,"type":"float","access":"rw"},
{"name":"Id_measured","id":240,"type":"float","access":"rw"},
{"name":"I_measured_report_filter_k","id":241,"type":"float","access":"rw"},
{"name":"max_allowed_current","id":242,"type":"float","access":"r"},
{"name":"overcurrent_trip_level","id":243,"type":"float","access":"r"}]},
{"name":"drv_fault","id":244,"type":"uint16","access":"r"}]},
{"name":"TIMING_LOG_GENERAL","id":245,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_ADC_CB_I","id":246,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_ADC_CB_DC","id":247,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_MEAS_R","id":248,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_MEAS_L","id":249,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_ENC_CALIB","id":250,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_IDX_SEARCH","id":251,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_FOC_VOLTAGE","id":252,"type":"uint16","access":"r"},
{"name":"TIMING_LOG_FOC_CURRENT","id":253,"type":"uint16","access":"r"}]},
{"name":"pre_calibrated","id":254,"type":"bool","access":"rw"},
{"name":"pole_pairs","id":255,"type":"int32","access":"rw"},
{"name":"calibration_current","id":256,"type":"float","access":"rw"},
{"name":"resistance_calib_max_voltage","id":257,"type":"float","access":"rw"},
{"name":"phase_inductance","id":258,"type":"float","access":"rw"},
{"name":"phase_resistance","id":259,"type":"float","access":"rw"},
{"name":"direction","id":260,"type":"int32","access":"rw"},
{"name":"motor_type","id":261,"type":"uint8","access":"rw"},
{"name":"current_lim","id":262,"type":"float","access":"rw"},
{"name":"inverter_temp_limit_lower","id":263,"type":"float","access":"rw"},
{"name":"inverter_temp_limit_upper","id":264,"type":"float","access":"rw"},
{"name":"requested_current_range","id":265,"type":"float","access":"rw"},
{"name":"current_control_bandwidth","id":266,"type":"float","access":"rw"}]}]},
{"name":"error","id":267,"type":"uint8","access":"rw"},
{"name":"pos_setpoint","id":268,"type":"float","access":"rw"},
{"name":"vel_setpoint","id":269,"type":"float","access":"rw"},
{"name":"vel_integrator_current","id":270,"type":"float","access":"rw"},
{"name":"current_setpoint","id":271,"type":"float","access":"rw"},
{"name":"vel_ramp_target","id":272,"type":"float","access":"rw"},
{"name":"vel_ramp_enable","id":273,"type":"bool","access":"rw"},
{"name":"control_mode","id":274,"type":"uint8","access":"rw"},
{"name":"pos_gain","id":275,"type":"float","access":"rw"},
{"name":"vel_gain","id":276,"type":"float","access":"rw"},
{"name":"vel_integrator_gain","id":277,"type":"float","access":"rw"},
{"name":"vel_limit","id":278,"type":"float","access":"rw"},
{"name":"vel_limit_tolerance","id":279,"type":"float","access":"rw"},
{"name":"vel_ramp_rate","id":280,"type":"float","access":"rw"},
{"name":"setpoints_in_cpr","id":281,"type":"bool","access":"rw"}]},
{"name":"set_pos_setpoint","id":282,"type":"function","inputs":[
{"name":"pos_setpoint","id":283,"type":"float","access":"rw"},
{"name":"vel_feed_forward","id":284,"type":"float","access":"rw"},
{"name":"current_feed_forward","id":285,"type":"float","access":"rw"}],"outputs":[]},
{"name":"set_vel_setpoint","id":286,"type":"function","inputs":[
{"name":"vel_setpoint","id":287,"type":"float","access":"rw"},
{"name":"current_feed_forward","id":288,"type":"float","access":"rw"}],"outputs":[]},
{"name":"set_current_setpoint","id":289,"type":"function","inputs":[
{"name":"current_setpoint","id":290,"type":"float","access":"rw"}],"outputs":[]},
{"name":"move_to_pos","id":291,"type":"function","inputs":[
{"name":"pos_setpoint","id":292,"type":"float","access":"rw"}],"outputs":[]},
{"name":"move_incremental","id":293,"type":"function","inputs":[
{"name":"displacement","id":294,"type":"float","access":"rw"},
{"name":"from_goal_point","id":295,"type":"bool","access":"rw"}],"outputs":[]},
{"name":"start_anticogging_calibration","id":296,"type":"function","inputs":[],"outputs":[]}]},
{"name":"error","id":297,"type":"uint8","access":"rw"},
{"name":"is_ready","id":298,"type":"bool","access":"rw"},
{"name":"index_found","id":299,"type":"bool","access":"rw"},
{"name":"shadow_count","id":300,"type":"int32","access":"rw"},
{"name":"count_in_cpr","id":301,"type":"int32","access":"rw"},
{"name":"interpolation","id":302,"type":"float","access":"rw"},
{"name":"phase","id":303,"type":"float","access":"r"},
{"name":"pos_estimate","id":304,"type":"float","access":"rw"},
{"name":"pos_cpr","id":305,"type":"float","access":"rw"},
{"name":"hall_state","id":306,"type":"uint8","access":"r"},
{"name":"vel_estimate","id":307,"type":"float","access":"rw"},
{"name":"calib_scan_response","id":308,"type":"float","access":"r"},
{"name":"mode","id":309,"type":"uint8","access":"rw"},
{"name":"use_index","id":310,"type":"bool","access":"rw"},
{"name":"find_idx_on_lockin_only","id":311,"type":"bool","access":"rw"},
{"name":"pre_calibrated","id":312,"type":"bool","access":"rw"},
{"name":"zero_count_on_find_idx","id":313,"type":"bool","access":"rw"},
{"name":"cpr","id":314,"type":"int32","access":"rw"},
{"name":"offset","id":315,"type":"int32","access":"rw"},
{"name":"offset_float","id":316,"type":"float","access":"rw"},
{"name":"enable_phase_interpolation","id":317,"type":"bool","access":"rw"},
{"name":"bandwidth","id":318,"type":"float","access":"rw"},
{"name":"calib_range","id":319,"type":"float","access":"rw"},
{"name":"calib_scan_distance","id":320,"type":"float","access":"rw"},
{"name":"calib_scan_omega","id":321,"type":"float","access":"rw"},
{"name":"idx_search_unidirectional","id":322,"type":"bool","access":"rw"},
{"name":"ignore_illegal_hall_state","id":323,"type":"bool","access":"rw"}]},
{"name":"set_linear_count","id":324,"type":"function","inputs":[
{"name":"count","id":325,"type":"int32","access":"rw"}],"outputs":[]}]},
{"name":"error","id":326,"type":"uint8","access":"rw"},
{"name":"phase","id":327,"type":"float","access":"rw"},
{"name":"pll_pos","id":328,"type":"float","access":"rw"},
{"name":"vel_estimate","id":329,"type":"float","access":"rw"},
{"name":"vel_limit","id":333,"type":"float","access":"rw"},
{"name":"decel_limit","id":335,"type":"float","access":"rw"},
{"name":"A_per_css","id":336,"type":"float","access":"rw"}]}]},
{"name":"watchdog_feed","id":337,"type":"function","inputs":[],"outputs":[]}]},
{"name":"can","type":"object","members":[
{"name":"node_id","id":338,"type":"uint8","access":"r"},
{"name":"TxMailboxCompleteCallbackCnt","id":339,"type":"uint32","access":"r"},
{"name":"TxMailboxAbortCallbackCnt","id":340,"type":"uint32","access":"r"},
{"name":"received_msg_cnt","id":341,"type":"uint32","access":"r"},
{"name":"received_ack","id":342,"type":"uint32","access":"r"},
{"name":"unexpected_errors","id":343,"type":"uint32","access":"r"},
{"name":"unhandled_messages","id":344,"type":"uint32","access":"r"}]},
{"name":"test_property","id":345,"type":"uint32","access":"rw"},
{"name":"test_function","id":346,"type":"function","inputs":[
{"name":"delta","id":347,"type":"int32","access":"rw"}],"outputs":[
{"name":"result","id":348,"type":"int32","access":"rw"}]},
{"name":"get_oscilloscope_val","id":349,"type":"function","inputs":[
{"name":"index","id":350,"type":"uint32","access":"rw"}],"outputs":[
{"name":"result","id":351,"type":"float","access":"rw"}]},
{"name":"get_adc_voltage","id":352,"type":"function","inputs":[
{"name":"gpio","id":353,"type":"uint32","access":"rw"}],"outputs":[
{"name":"result","id":354,"type":"float","access":"rw"}]},
{"name":"save_configuration","id":355,"type":"function","inputs":[],"outputs":[]},
{"name":"erase_configuration","id":356,"type":"function","inputs":[],"outputs":[]},
{"name":"reboot","id":357,"type":"function","inputs":[],"outputs":[]},
JSON checksum: 0x59 0x33
malformed member : unsupported codec json
Connected to ODrive 336B31643536 as odrv0
One last aside… If I download the odrive github repo, navigate to the /tools directory, and run “sudo python3 setup.py build” I get the error
error: package directory 'fibre' does not exist
It looks like there is some stuff in setup.py to try to add that directory (from a nearby folder) to the path, but I guess that is failing. If I just copy the fibre directory to the tools directory, I get a different error:
package init file 'fibre/__init__.py' not found (or not a regular file)
So I’m really not sure how to even install this package from source if I want to make changes, since that seems broken.
All in all I’m having a whale of a time. I’ve got 6 Odrives and I just ordered two more. Halp. (:
EDITS: Two things. I just double checked that flashing the latest firmware does not help. It doesn’t. As far as that JSON message when my laptop connects, I just realized that is only shown when I use the -v flag on odrivetool, so maybe that’s perfectly normal.
