Hi everyone, I’m having trouble getting my Odrive to work, following instructions as below:
https://docs.odriverobotics.com/
https://docs.odriverobotics.com/encoders
I’m using an Odrive 3.4 48V, a T Motor 5212 and an AS5047D encoder with ABI interface.
I follow the “Getting Started” instructions to the step “save configuration and reboot” then I turn to the instructions on setting up encoder, where I get the problem. After I run
odrv0.axis1.requested_state = AXIS_STATE_ENCODER_OFFSET_CALIBRATION
check errors by
dump_errors(odrv0)
I get axis error ERROR_INVALID_STATE on axis1.
here is my config info:
Encoder config:
mode = 0 (int)
use_index = False (bool)
pre_calibrated = False (bool)
cpr = 2000 (int)
offset = 0 (int)
offset_float = 0.0 (float)
bandwidth = 1000.0 (float)
Motor Config:
pole_pairs = 11 (int)
phase_inductance = 0.0 (float)
phase_resistance = 0.0 (float)
direction = 0 (int)
motor_type = 2 (int)
current_lim = 10.0 (float)
current_lim_tolerance = 1.25 (float)
I can get the encoder readings by shadow_count. I am not sure I provided enough information, please ask me if more is needed, thank you.
