Hi, I’m running some BLDC motors (1kW running at around 20V) sensorlessly with an ODrive v5.6. The motors are part of a mowing system and they have blades attached to them (one motor has larger blades attached than the other).
I’ve followed ODrive’s guide as well as other forum posts to get my motors running, and I have them sort of running, but not reliably. Here are the issues I’m facing:
Half the time during ramp-up the motor seems to “miss” the ODrive’s commutation and starts to spin in the wrong direction at a very low speed. This problem is avoided if I give the blades attached to the rotor an initial push in the correct direction, but obviously this isn’t a realistic solution for production. How can I fix this?
When I first setup the controller I was getting the
MOTOR_ERROR_DC_BUS_OVER_REGEN_CURRENTerror (note that I am not using a brake resistor), which I solved by fiddling with thedc_mac_negative_currentandmax_regen_currentparameters. I had to set both of them very high (greater thanabs(150)) for the ramp up to succeed without cutting out. 150A seems like a rediculous number to me - are these numbers to be expected? -
When I try to run the motor with the larger blade connected, I can’t get it to ramp up to the speed I want no matter how much I raide the parameters listed in ^2. I’d like to have
sensorless_ramp.velreach 1500, but the most I can reliably achieve is 500 before the power cuts off due to some setting. Increasingmotor.config.requested_current_rangeandmotor.config.current_limseemed to help somewhat (not sure if one or both had an effect).
Errors:
There are the errors I’m seeing when trying to run the motor with the larger blades:
dump_errors(odrv0)
system: no error
axis: no error
motor: no error
axis1
axis: no error
motor: Error(s):
MOTOR_ERROR_CURRENT_SENSE_SATURATION
MOTOR_ERROR_CURRENT_LIMIT_VIOLATION
MOTOR_ERROR_UNKNOWN_CURRENT_MEASUREMENT
General config
In [122]: odrv0.axis1.config
Out[122]:
calibration_lockin:
accel: 20.0 (float)
current: 10.0 (float)
ramp_distance: 3.1415927410125732 (float)
ramp_time: 0.4000000059604645 (float)
vel: 40.0 (float)
can:
encoder_rate_ms: 10 (uint32)
heartbeat_rate_ms: 100 (uint32)
is_extended: False (bool)
node_id: 1 (uint32)
dir_gpio_pin: 8 (uint16)
enable_sensorless_mode: True (bool)
enable_step_dir: False (bool)
enable_watchdog: False (bool)
general_lockin:
accel: 20.0 (float)
finish_distance: 100.0 (float)
finish_on_distance: False (bool)
finish_on_enc_idx: False (bool)
finish_on_vel: False (bool)
vel: 40.0 (float)
sensorless_ramp:
accel: 200.0 (float)
finish_on_vel: True (bool)
vel: 800.0 (float)
startup_closed_loop_control: False (bool)
startup_encoder_index_search: False (bool)
startup_encoder_offset_calibration: False (bool)
startup_homing: False (bool)
startup_motor_calibration: False (bool)
step_dir_always_on: False (bool)
step_gpio_pin: 7 (uint16)
watchdog_timeout: 0.0 (float)
Controller config
In [124]: odrv0.axis1.controller.config
Out[124]:
anticogging:
anticogging_enabled: True (bool)
calib_anticogging: False (bool)
calib_pos_threshold: 1.0 (float)
calib_vel_threshold: 1.0 (float)
cogging_ratio: 1.0 (float)
index: 0 (uint32)
pre_calibrated: False (bool)
axis_to_mirror: 255 (uint8)
control_mode: 2 (uint8)
electrical_power_bandwidth: 20.0 (float)
enable_torque_mode_vel_limit: True (bool)
enable_vel_limit: True (bool)
homing_speed: 0.25 (float)
inertia: 0.0 (float)
input_mode: 1 (uint8)
load_encoder_axis: 1 (uint8)
mechanical_power_bandwidth: 20.0 (float)
mirror_ratio: 1.0 (float)
pos_gain: 20.0 (float)
spinout_electrical_power_threshold: 10.0 (float)
spinout_mechanical_power_threshold: -10.0 (float)
steps_per_circular_range: 1024 (int32)
torque_mirror_ratio: 0.0 (float)
torque_ramp_rate: 0.009999999776482582 (float)
vel_gain: 0.009999999776482582 (float)
vel_integrator_gain: 0.05000000074505806 (float)
vel_integrator_limit: inf (float)
vel_limit: 1000.0 (float)
vel_limit_tolerance: 1.2000000476837158 (float)
vel_ramp_rate: 1.0 (float)
Motor config
In [123]: odrv0.axis1.motor.config
Out[123]:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
current_control_bandwidth: 1000.0 (float)
current_lim: 100.0 (float)
motor_type: 0 (uint8)
phase_inductance: 2.147314080502838e-05 (float)
phase_resistance: 0.024812055751681328 (float)
pole_pairs: 7 (int32)
requested_current_range: 60.0 (float)
torque_constant: 0.03999999910593033 (float)
torque_lim: inf (float)
Happy to provide any additional info!
Thanks in advance.
