Hi all
I am trying to compile the latest firmware from github. After make i get the following tup error
- python interface_generator_stub.py --definitions odrive-interface.yaml --template fibre/cpp/type_info_template.j2 --output autogen/type_info.hpp
*** tup messages ***
tup error: File ‘C:/Users/Unknown/AppData/Local/Programs/Python/Python38-32/lib/importlib/pycache/metadata.cpython-38.pyc’ was written to, but is not in .tup/db. You probably should specify it as an output
– Delete: C:/Users/Unknown/AppData/Local/Programs/Python/Python38-32/lib/importlib/pycache/metadata.cpython-38.pyc
*** Command failed due to errors processing the output dependencies.
- python interface_generator_stub.py --definitions odrive-interface.yaml --generate-endpoints ODrive --template fibre/cpp/endpoints_template.j2 --output autogen/endpoints.hpp
tup error: File ‘C:/Users/Unknown/AppData/Local/Programs/Python/Python38-32/lib/encodings/pycache/unicode_escape.cpython-38.pyc’ was written to, but is not in .tup/db. You probably should specify it as an output
– Delete: C:/Users/Unknown/AppData/Local/Programs/Python/Python38-32/lib/encodings/pycache/unicode_escape.cpython-38.pyc
[ ETA~=24s Remaining=85 Active=0 ] 2%
*** tup: 2 jobs failed.
make: *** [all] Error 1
I am in using windows 64 and found some reference to the problem here:
However the solution is not working as i don;t have the setting described there.
Does anyone know how to fix this?
