Pretty sure it’s the same as before? odrv0.axis0.controller.config.control_mode = CTRL_MODE_VELOCITY_CONTROL (which is mode 2) Then you set vel_setpoint
Hi @Wetmelon, thank you, I will have a play with that, I may upgrade the firmware as I like the idea of the filters between input command and cascade system, although that’s a lot of code change on my part which I didn’t have time before the event.
Is there a link still to the old documentation for 4.11 as my link on my desktop no longer works?
Thank you again,
Neil.
Ah, I was typing this: -
And not: -
Haha, thank you.
