I recently purchased 2 ODrive V3.6 24V boards. My development machine is Ubuntu 18.04 Linux machine. Neither of the boards shows up as a USB device in Linux (lsusb does not show the device, dmesg does not show the device being detected on USB, it shows nothing when the device is connected.)
= I am powering them (for now) with a 13.5V power supply.
= I have tried another, different Ubuntu 19.04 Linux machine.
= The green power light comes “on” on both boards when power is applied.
= Though I originally had motor + encoder + resistor connected I have tried with no other connections to the board (no motor, no resistor, no encoder)
= I have swapped out 2 different USB cables.
= On one of the two boards I have switched it into DFU mode.
= It shows up just fine in Linux as a DFU / usb device.
= I have flashed released firmware images for v0.4.11, v0.4.12, and v0.5.1 to the board with DFU
= I have put the switch back into run, and cycled power and => still nothing.
= I have flashed released firmware images for V0.4.11 and v0.4.12 on it with ST-LINK programmer and cycled power and => still nothing.
= I have left the other board alone and just tried to see if it showed similar symptoms.
I’m not sure what else to try at this point.
Thanks for any advice…
The two boards seem identical in behavior regardless of what I do. With the switch in DFU mode (or on STLINK) it is like the processor is there and everything is fine (I’ve done a ton of STM32X development on Linux for years) and when I put the switch back to RUN it is like the processor just locks up on startup or something.
[Edit] I read the other posts on this topic as well, but they didn’t quite seem to cover what I’m seeing exactly so I started this thread.
This is most similar to the problem posted (unanswered) a year ago: https://discourse.odriverobotics.com/t/usb-not-being-detected/3009
