Hi all,
I’m a newbie, so please be kind ![]()
Wondering if any of you good sports be able to help with the below.
following the manual getting started with ODrive v3.6 under Ubuntu 22.04.1. But odrive won’t launch, despite me adding
export PATH=$PATH:~/.local/bin
to my bashrc and restarting the terminal.
Also I can’t seem to find the executable in either directory. The command odr autocompletes with tab, but then comes up with “Command ‘odrivetool’ not found, did you mean: …”
Any ideas, if I missing something?
re-running the sudo pip3 install --upgrade odrive will only tell me that the conditions are already satisfied and it point to /usr/local/lib/python3.10/dist-packages/odrive
No idea what’s wrong :-/
Please someone help. Thanks guys!
