I was trying to make a two-wheeled platform so I basically followed this tutorial:
only changing some parameters. I’ve got both motors running nice.
Problem is that if I run:
I’m unable to operate axis1 until I reboot and run the command for axis1 only. I’m unable to operate both at the same time and can’t find the solution. Any ideas? If I tried to config both axis state in startup procedure I also get only first axis to operate.
I’m using odrivetool in Anaconda Powershell Promt under windows 8. I have no errors in the console. Simply it does not respond to the second command but it’s still operational. For example I can change the target velocity and it’s responding correctly.
I’m using board 3.4 with preflashed software version 0.3.7 if I remember correctly.
When I boosted the spinup current limit from 10 to 30A it started to work on both axis. No idea how to explain this and what it has in common with hall signal error. Ridiculous.
It can’t hurt to double check that all setting are properly saved on both axis after reboot. Just paste odrv0.axis0 and odrv0.axis1 into a textcompare after rebooting. Also check .motor and .encoder.
