I received this error after the update:
pi@raspberrypi:~ $ sudo odrivetool dfu
ODrive control utility v0.5.1
Waiting for ODrive...
Downloading json data from ODrive... (this might take a while)
Found ODrive 207A3589524B (v3.6-56V) with firmware v0.4.11-dev
Checking online for newest firmware... found v0.5.1
Downloading firmware v0.5.1...
Saving configuration to /tmp/odrive-config-207A3589524B.json...
Configuration saved.
Putting device 207A3589524B into DFU mode...
Erasing... done
Flashing... done
Verifying... done
Waiting for the device to reappear...
File "/usr/local/bin/odrivetool", line 143, in <module>
File "/usr/local/lib/python3.7/dist-packages/odrive/dfu.py", line 457, in launch_dfu
File "/usr/local/lib/python3.7/dist-packages/odrive/dfu.py", line 421, in update_device
odrive.configuration.restore_config(device, None, logger)
File "/usr/local/lib/python3.7/dist-packages/odrive/configuration.py", line 70, in restore_config
with open(filename) as file:
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/odrive-config-unknownserialnumber.json'
python3: ../../libusb/io.c:2116: handle_events: Assertion `ctx->pollfds_cnt >= internal_nfds' failed.
Aborted
What is it trying to say and what should I do?
