Hey there,
the question is already in the topic title. Can I use an SSI-SPI Adapter to use SSI encoders with the Odrive?
I have a motor I’m currently interested that would come with an SSI encoder. I’ve seen that SSI is currently not supported by Odrive. I’ve come across this SSI-SPI adapter from Roboteq and wonder if it would work together with the odrive?
Umm, looks like it might work? Try it out!
But ODrive doesn’t support just arbitrary 16-bit input, so you may have to let us know what encoder you’re running on the other end.
Well I don’t have an encoder yet. I’m looking into possible motors preferably with encoders attached already. Maybe let me ask the question different. I do know that there is this encoder guide:
But if I see an absolute encoder on a manufacturer site. How can I be sure that it works with the Odrive? Do I have to make sure that they have one of the supported chips like AMS - AS5047P?
I would be interested in the NME2-SSI by Nanotec:
Full docu can be found here: https://en.nanotec.com/fileadmin/files/Datenblaetter/Encoder/NME2/NME2_Technical-Datasheet_V1.0.2.pdf
