Hi!
I am attempting to run a 24V BLDC Motor (P/N: 42BLS100-24-01) with a CUI Encoder attached (P/N AMT213A-V).
However, when following through the getting started documentation, when I get to the line where you run the calibration sequence (i.e. odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE), the motor spins one direction four rotations and then stops.
When I run the dump_errors(odrv0) command, I get the following two errors:
axis: Error(s):
ERROR_ENCODER_FAILED
motor: no error
encoder: Error(s):
ERROR_NO_RESPONSE
I do not have a Z connection from the encoder, but I am sure it is set to not need it for the calibration anyway.
Is it possible that this encoder is not supported via ODrive?
If this is the case, is there any steps that I can take to make it compatible?
I appreciate the help in advance!
