Hello there. I am looking for some assistance with the parameters used for my current setup. I have the 54V version of the odrive currently hooked up to a T-Motor RI 150. I am using the AMT 102-V. I went through the startup procedure and successfully calibrated my motor however when i put the motor into closed loop control it go so hot that it melted the 3D printed enclosure without any load (<230 C). These are the parameters of my motor.
My question is am i correct in using the following motor parameters:
odrv0.axis0.motor.config.current_limit = 15
odrv0.axis0.motor.config.calibration_current = 5
odrv0.axis0.motor.config.resistance_calib_max_voltage = 10 taking into account the my v_bus is 30V
If these are correct my only other reasoning for the over heating was that the motor was shuddering and needed to be tuned.
