I keep hitting the same error whatever I do (resolder the encoder, use M0, use M1, reboot, use other motor, …), who knows what to do?
Here is a video off my test:
Thanks in advance for the help
Cheers
Carelsbergh Stijn
Cheers
Carelsbergh Stijn
Please list the Motor and Encoder error you are seeing. This makes it easier to understand what might be going wrong.
The definitions of each error are in the code (copied from https://docs.odriverobotics.com/troubleshooting)
Hi
I’m using a keda 63-64 motor, with an encoder from AliExpress. https://s.click.aliexpress.com/e/GjLQOBm
The problem is that the error code 0x101 is not the the troubleshooting guide
Cheers
Carelsbergh Stijn
What are the other errors? Or are they 0x00?
odrv0.axis1.motor.error
odrv0.axis1.encoder.error
Encoder error 0x2
Cheers
Carelsbergh Stijn
I’m not sure which encoder error you have, but one of these two:
ERROR_CPR_OUT_OF_RANGE = 0x02
ERROR_INDEX_NOT_FOUND_YET = 0x20,
For the CPR error, try changing the calibration range for the encoder (and after you find the accepted range, change the CPR value to what it should be). odrv0.axis0.encoder.config.calib_range and odrv0.axis0.encoder.config.cpr .
For the index_not_found error; are you sure your encoder has an index and that the Z-wire is connected properly? Can you confirm this with a multimeter? You can also try setting odrv0.axis0.encoder.config.use_index to false.
My encoder doesn’t have an index so I have to set it to false do I have to use this command?
odrv0.axis0.encoder.config.use_index = false
Cheers
Carelsbergh Stijn
Yes. Do not forget to save your configuration and reboot before continuing. After rebooting always confirm that the settings you changed were saved.
odrv0.save_configuration()
odrv0.reboot()
odrv0 = odrive.find_any()
Hi
Thanks a lot I will try it later today
Cheers
Carelsbergh Stijn
I checked and the index was already set to false, so I guess it is the other problem, what do I have to do too solve this? (Cpr out of range)
Cheers
Carelsbergh Stijn
You need to check your motor pole pair setting and your encoder cpr setting.
Hi
I’ve done that and it seems like evertthing is correct. What can I do? Maybe the seller told me a wrong cpr?
Cheers
Carelsbergh Stijn
Hi Stjn,
I checked the correct cpr with the command : odrv0.axis1.encoder.shadow_count (its somewhere here in the Odrive documentation, but cant find it anymore)
If I remember correctly the procedure was like this:
Regarding the pole pairs: we both have the same motors and they have 7 pole pairs
regards Peter
Thanks for the advice
Cheers
Carelsbergh Stijn
