What is the max speed the Odrive S1 can handle?
Hello! I’m planning on driving this motor with the ODrive S1 at 80% Throttle (which at 48V with a 12S lipo would spin at between 4.3 and 4.4K RPM). Would the ODrive S1 be capable of handling the high speed?
There are a few potential limiting factors like the desired acceleration, what kind of load it will be under, and how may pole pairs the motor has (not immediately obvious from the link).
While there is no enforced limit, anything below ~36,000eRPM should work just fine (electrical RPM, need pole pair count to convert to mechancial RPM).
