Windows tool chain problem
#1
I recently get myself an Odrive. I’ve managed to get it up and running quite seamless with hoverboard motor, it works impressive.
But now I would like to do some changes in code, to make Odrive better suit my needs.
I’ve gone through a lot of problems in setting up toolchain on Win7, but finally I’ve got stuck.
I get following problem while trying to compile:
> Executing task in folder Firmware: make <
 [                    ETA~=??? Remaining=80 Active=4                     ]   0%U
nable to retrieve WOW64 info
tup error: failed to inject dll: No such file or directory
 *** Command ID=335 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32
F4xx_HAL_Driver/Src\stm32f4xx_hal_cortex.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MIN
Any help would be appreciated.
#2
Please do: make -v and arm-none-eabi-gcc --version
Also, are you on 32 or 64 bit Windows 7? Doesn’t look like Tup is guaranteed to work with 32 bit systems. https://github.com/gittup/gittup/issues/11
#3
Thanks for quick answer, here are versions:
GNU Make 3.81
arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 7-2017-q4-major) 7.2.1
20170904 (release) [ARM/embedded-7-branch revision 255204]
The system is 64 bit.
#4
I had the same exact problem,
Unable to retrieve WOW64 info
I tracked my issue down to McAFee removing tup32det.exe
I backed down from the latest version of tup to 7.8 and McAFee didn’t try and delete.
Now I build successfully
