Would a BLDC/PMSM Hall + encoder alignment tool be useful?
Hi everyone,
I am an engineer working on robotics and considering building a compact tool for BLDC/PMSM motor bring-up and commissioning after having a lot of issues there.
The idea is a device that connects to the motor phases, Hall sensors, and incremental encoder signals. After a short alignment procedure, with one click it would help identify things like:
  • Correct Hall sequence
  • Encoder direction
  • Phase/Hall/encoder mismatch
  • Hall sector angles
  • Commutation offset
  • Possible wiring mistakes
The goal is to make motor bring-up easier, especially when working with Hall sensors and incremental encoders, without having to manually debug everything with an oscilloscope or logic analyzer.
I am still validating whether this is a real need before spending serious time on the hardware.
Would a tool like this be useful in your work or projects?
How do you currently solve Hall/encoder/phase alignment problems?
Any feedback, criticism, or “I would not need this because…” comments would be very helpful.
Best regards
Hi! That’s a very cool idea. Typically with ODrive products, all of that is built into the initial calibration routine – the ODrive does all the hall sequencing, encoder commutation offset, etc automatically. But there’s definitely a lot of stories I’ve heard where motor manufacturers have significant motor-to-motor variation in sensor placement/performance that doesn’t play well with non-ODrive products.
