Ok, I have a slightly embarrassing chicken and egg problem.
I am following these instructions:
Use the Zadig utility to set ODrive driver to libusb-win32.
Check ‘List All Devices’ from the options menu, and select ‘ODrive 3.x Native Interface (Interface 2)’. With that selected in the device list choose ‘libusb-win32’ from the target driver list and then press the large ‘install driver’ button.
I plug in the ODrive and power it up and Zadig shows the device, but Win7 installs a driver before I can do anything (or Zadig fails to install if I try to do it really quickly)
Then from Device Manager I uninstall the driver, but Zadig won’t see it again until I unplug it and plug it back in, at which time, you guessed, Win7 installs a driver.
So is there any way to manually install the correct driver from Device Manager? Or tell Win7 not to install a driver?
The driver win7 installs doesn’t work:
usb.core.NoBackendError: No backend available
Thanks,
DougM
