Hi guys,
Here I am, back again and this time with a project. I’m building a 6 DOF racesimulator. Here are some pictures off the disign, if there are any questions, feel free to ask me.
Cheers Stijn
Hi guys,
Cheers Stijn
Very cool! Man y’all are making me want one now. What do you have as far as the frame goes? I assume there is a common design that is followed?
Yes there is in fact a common disign that is followed but it’s still pretty adjustable, so I’m not sure on the frame yet.
Cheers Stijn
Looks right to me, but you may be able to skip the “Arduinos” part, depending on the outputs you have from simtools
Hi Stijn, looking good
What motors/screws ect; have you chosen?
And tell us a little about torque speed and so on.
Jerry.
Okay thanks
Cheers
Hi Sijn,
Wetmelon is right. You can skip the arduino stuff. Connect it direct to the Gaming PC. You will need three USB Ports for the three ODrives, but you can drive all of it with one Game engine of SimTools.
Great to hear you are starting.
Greetings / Zennix
Hi
Great to hear back from you, do you have the code to do it? And do you have the code for the limit switches?
Cheers Stijn
I’m building this thing for my graduation project, and I also need to make a small ‘book’ about it, I need to write information on the parts I use in the project, is there someone that has a good explaination of what an ODrive is what it does how it does it and so on?
Also does someone know if you can het a sponsorship from ODrive?
Thanks for all the help guys!
Cheers Stijn
Hi Stijn,
find the code here: End switches an interrupts
But there are still some issues with it. Hopefully the bugs are fixed till you need the software.
Greetings / Zennix
Thanks
Cheers
Stijn
There is a little bit of info about how the control loops work available in the documentation.
As for sponsorship, please email info@odriverobotics.com.
Thanks for the reply
Cheers
Stijn
I’m working hard on my racesimulator and I’m trying to do it as fast as possible so that it doesn’t take forever. Here are some pictures
Also I wanted to ask if someone knows what steering wheel I need? I want to play on pc is that the g920 or the g29 or …
Cheers
Carelsbergh Stijn
Hi Stijn,
great work
My steering wheel is a Logitec G27. Works great.
Greetings / Zennix
Hi all,
I’ve been very bussy working on the project. Here are some pictures.
(The wooden frame is for testing)
Hi Stijn,
nice work. Do you think the wood construction, is stiff enough?
I love your chair:grin:
Greetings / Zennix
Hi zennix,
No, not at all, I just made it to be able to see how it would look, if it isn’t to big or small and to see if there are any impossible things that I didn’t think of in the first place
Cheers
Carelsbergh Stijn
Hi Stijn,
did you design the rig by yourself?
I know that you can simulate the construction with simtools in sketchup. I didn’t tried it out. Do you?
Greetings / Zennix
