Hi Stijn!
thanks a lot for the information!
I still have to solve one thing with my actuator/simulator - and maybe you could help? This is the calibration sequence at each start. At my tests with my actuator-prototype I found that a load on the actuator during the calibration sequence exceeding 10 kg will not work reliably. So the whole platform should not exceed complete 60kg. I dont think this is possible. How did you solve this problem?
Wickie
Hi
I donβt know how much my platform weighs but for me this was not a problem, maybe just set the maximum current a bit higher?
Cheers
Hi guys
Here is a video on my YouTube channel, you can subscribe if you want. I will make more projects and also share how I made my racesim, because I didnβt have the time to do it during the project.
Cheers
Carelsbergh Stijn
Hello all
Iβve finally gotten around to making a video on the mechanical build process, video on the electrical build process coming soon!
Please consider subscribing. ![]()
Hope you like the video, if you have a suggestion on another video like a detailed overview of the project, let me know! ![]()
Cheers
Carelsbergh Stijn
Hello, long time no see.
Iβve made a quick video about the electronics case, you can check it out here:
Cheers
Carelsbergh Stijn
Hello
I made a video on how to set up ODrive completely for a racing simulator using FlyPT Mover, you can check it out here. If there are any questions, you can ask them here or in the comments.
Setting up ODrive with FlyPT Mover for a 6 DOF Racing Simulator (USB ASCII) - YouTube
Cheers
Carelsbergh Stijn
