About the ODrive Pro Support category
If you need help with your ODrive Pro this is the place to get it.
We purchased the ODrive Pro board to use with the Web GUI. Later, we discovered that the board does not support a brake resistor. According to the ODrive documentation, the ODrive Pro can operate with a battery if a brake resistor is not available.
We connected a 5065 270KV motor along with an AMT102 encoder. Brake resistor settings were disabled, and the DC bus voltage limit was set to 50V. The battery voltage was 56.5V. However, after loading the configuration, we received a “DC bus over-voltage” error.
We would prefer not to purchase a regen clamp. What is the recommended way to test the motor in this setup?
how should i config the parameters to make it work.
