I have multiple ODrive Pro controllers connected to the same CAN bus, but I’m facing an issue with one of them:
Setup: ODrive A, B, and C are on the same CAN bus.
Working Behavior: ODrive A and B communicate normally; I can send and receive data.
Issue with ODrive C:
- I can move the motor via USB, but it does not send or receive data on the CAN bus.
- It does not work whether it is connected alone or with A and B.
- It does not work when swapping the cables from A or B to C, ruling out a wiring issue.
- Changing its CAN ID to match A or B (and A or B to C) does not make it work, while A and B still function with the swapped ID, ruling out a software issue on the PC side.
- It is running the latest firmware, same as A and B. (config is also the same except for motor calibration and CAN id of course)
Most importantly I measure 0V across CANH and CANL for Odrive C while I get good voltage across for the other Odrives that are working (Only one Odrive on the bus at a time while measuring that) - If no CAN wires are connected and I power it using usb I get a voltage to gnd but not across H and L.
So I believe that is an issue with the Odrive?
