I am seaching for any information on AXIS ERROR 512. Documentation provided on the website does not clearly explain the root cause of this error and how to fix it. Error only occurs when operating in closed loop control. I can provide more information as needed to better explain the failure mode.
Have you tried the dump_errors command?
i.e. dump_errors(odrv0) from the odrivetool shell
Have tried it many times for various reasons. dump.errors seems to not respond. see below
In [88]: dump_errors(odrv0)
NameError Traceback (most recent call last)
C:\ProgramData\Anaconda3\lib\site-packages\fibre\shell.py in ()
----> 1 dump_errors(odrv0)
NameError: name ādump_errorsā is not defined
In [89]:
But we see the error by calling axis1 errors as below:
In [62]: odrv0.axis1.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
In [63]: odrv0.axis1.error
Out[63]: 512
What version of odrivetool are you using and what is the firmware version (odrv0.fw_version_minor)?
Axis error 512 is 0x200 which is no longer a valid error in 0.5.2, so weāll have to determine your version first.
Please see below:
ODrive control utility v0.4.7
Please connect your ODrive.
Connected to ODrive 387437803437 as odrv0
In [1]:
In [4]: odrv0
Out[4]:
vbus_voltage = 14.71142578125 (float)
serial_number = 387437803437 (int)
hw_version_major = 3 (int)
hw_version_minor = 5 (int)
hw_version_variant = 24 (int)
fw_version_major = 0 (int)
fw_version_minor = 4 (int)
fw_version_revision = 7 (int)
fw_version_unreleased = 0 (int)
user_config_loaded = True (bool)
brake_resistor_armed = True (bool)
system_stats:
uptime = 73898874 (int)
min_heap_space = 14264 (int)
min_stack_space_axis0 = 7860 (int)
min_stack_space_axis1 = 7772 (int)
min_stack_space_comms = 3136 (int)
min_stack_space_usb = 1196 (int)
min_stack_space_uart = 3964 (int)
min_stack_space_usb_irq = 1828 (int)
min_stack_space_startup = 556 (int)
usb: ...
i2c: ...
config:
brake_resistance = 0.4699999988079071 (float)
enable_uart = True (bool)
enable_i2c_instead_of_can = False (bool)
enable_ascii_protocol_on_usb = True (bool)
dc_bus_undervoltage_trip_level = 8.0 (float)
dc_bus_overvoltage_trip_level = 25.920001983642578 (float)
gpio1_pwm_mapping: ...
gpio2_pwm_mapping: ...
gpio3_pwm_mapping: ...
gpio4_pwm_mapping: ...
axis0:
error = 0x0000 (int)
step_dir_active = False (bool)
current_state = 1 (int)
requested_state = 0 (int)
loop_counter = 591178212 (int)
config: ...
get_temp()
motor: ...
controller: ...
encoder: ...
sensorless_estimator: ...
trap_traj: ...
axis1:
error = 0x0200 (int)
loop_counter = 591178204 (int)
config: ...
get_temp()
motor: ...
controller: ...
encoder: ...
trap_traj: ...
can:
node_id = 0 (int)
TxMailboxCompleteCallbackCnt = 0 (int)
TxMailboxAbortCallbackCnt = 0 (int)
received_msg_cnt = 0 (int)
received_ack = 0 (int)
unexpected_errors = 0 (int)
unhandled_messages = 0 (int)
test_property = 0 (int)
test_function(delta: int)
get_oscilloscope_val(index: int)
get_adc_voltage(gpio: int)
save_configuration()
erase_configuration()
reboot()
enter_dfu_mode()
Thanks. I went ahead and fixed your formatting for you (use three ābackticksā ```) before and after a pre-formatted block to get it like that)
You are on firmware version 0.4.7, which released on January 12 of 2018. Itās probably time to update
But to answer your question, axis error 0x0200 is ⦠CONTROLLER_FAILED. Which means you need to check axis1.controller.error
In [5]: odrv0.axis1.controller.error
Out[5]: 1
It looks like you are using the generic Fibre shell? That would explain why you have no dump_errors, because that is specific to odrivetool.
Can you run odrivetool from the ODrive Git repository?
i.e.:
git clone https://github.com/odriverobotics/ODrive.git
cd ODrive
git checkout fw-v0.5.1
python tools/odrivetool
Controller error 1 is ERROR_OVERSPEED
Probably, you need to increase vel_limit.
Also, you should checkout fw-v0.5.2 and update your firmware.
There have been many improvements since 0.5.1.
I will try to run it from the GIT repository. And we can update the firmware to take advantage of the improvements. I look forward to that.
The following are the present speed settings. Does vel_limit higher than 60000 make sense? Do you have a feeling for how much tolerance is acceptable?
Appreciate your help with this.
In [6]: odrv0.axis1.controller
Out[6]:
error = 0x0001 (int)
pos_setpoint = 286.75 (float)
vel_setpoint = 0.0 (float)
vel_integrator_current = 0.00034962789504788816 (float)
vel_ramp_target = 0.0 (float)
vel_ramp_enable = False (bool)
config:
control_mode = 2 (int)
pos_gain = 2.0 (float)
vel_gain = 0.03999999910593033 (float)
vel_integrator_gain = 0.05000000074505806 (float)
vel_limit = 60000.0 (float)
setpoints_in_cpr = False (bool)
set_pos_setpoint(pos_setpoint: float, vel_feed_forward: float, current_feed_forward: float)
move_to_pos(goal_point: float)
Are there any concerns about the new firmware on the older board?
Shouldnāt be an issue with an older board, just make sure you set the board version in tup.config when you build the firmware.
60000 sounds about reasonable for the old firmware - possibly a bit on the low side, depending on the motor.
In the old firmware, vel_limit, pos_setpoint etc were in encoder counts and counts/sec, so many settings e.g. control gains would vary with encoder resolution.
One of the many changes in the new firmware is that position and velocity are normalised to revolutions and revolutions/sec, so the default gains and limits are VERY different, but they work for a wider range of motors & encoders.
Also, in the new firmware you no longer set pos_setpoint or vel_setpoint directly, and move_to_pos is also gone. Instead you use controller.input_pos or input_vel, with one of the configurable input modes, which can be low-pass filtering, trapezoidal trajectory, etc.
Also in the new firmware, you can have it so that the velocity limit will actually limit the velocity rather than just triggering an error. (the error is still there, but only if it exceeds the limit by a configurable margin)
You can even use the velocity limit in torque mode.
Finally got back to this project. While trying to update the firmware with odrivetool dfu, we encountered an error during the flashing process that said " raise ValueError(āThe device has no langidā).
Since this, we cannot connect to the ODrive and after ffurther investigation,we donwloaded DfuSe Demo and the correct firmware hex file to manulally upload the firmnware to the ODrive.
In DfuSe, we are unalbe to select ODrive as an āAvaible DFU Deviceā to start the process to convert the hex into a dfu file to upload to the ODrive.
Any suggestions how to upload the firmware to ODrive with the current errors? Any suggestions or methods are welcomed.
Put the RUN/DFU switch into DFU, and then try dfu-util. Or use an STLink and flash with openocd.
Tried the first option earlier this evening. Got;
ādfu-utilā is not recognized as an internal or external command,
operable program or batch file.
I will look into how to use STLink and openocd.
Is this a usb communication error, or processor error?
Thanks for the help.
sudo apt install dfu-util⦠on Linux, of course.
USB, probably.
As Wetmelon says, I would strongly recommend using Linux (e.g. raspberry pi) to work with ODrive. Windows has a problem with USB devices using more than one driver (we need one to use the device and another to update firmware) whereas Linux just doesnāt have this problem, and it is so much easier to install & use open source tools like dfu-util, openocd, python etc.
That said, if you have no access to any kind of Linux environment
, you can try some Windows tools:
dfu-util: http://dfu-util.sourceforge.net/
st-link utility: STSW-LINK004 - STM32 ST-LINK utility (replaced by STM32CubeProgrammer) - STMicroelectronics (you can use this with either a ST nucleo board or a ST-Link V2 programmer, but it is cheaper to buy a nucleo board)
