We have two motors connected to M0 and M1, with unfiltered hall sensor input. They were set up according to https://docs.odriverobotics.com/hoverboard.html. The working config json is below. ODrive 3.5 48V with firmware 0.4.7.
config
  "config": {
    "brake_resistance": 2,
    "enable_uart": true,
    "enable_i2c_instead_of_can": false,
    "enable_ascii_protocol_on_usb": true,
    "dc_bus_undervoltage_trip_level": 8,
    "dc_bus_overvoltage_trip_level": 51.840003967285156
  "axis0": {
    "config": {
      "startup_motor_calibration": false,
      "startup_encoder_index_search": false,
      "startup_encoder_offset_calibration": false,
      "startup_closed_loop_control": true,
      "startup_sensorless_control": false,
      "enable_step_dir": false,
      "counts_per_step": 2,
      "step_gpio_pin": 1,
      "dir_gpio_pin": 2,
      "ramp_up_time": 0.4000000059604645,
      "ramp_up_distance": 12.566370964050293,
      "spin_up_current": 10,
      "spin_up_acceleration": 400,
      "spin_up_target_vel": 400
    "motor": {
      "config": {
        "pre_calibrated": true,
        "pole_pairs": 8,
        "calibration_current": 30,
        "resistance_calib_max_voltage": 4,
        "phase_inductance": 0.00002497009700164199,
        "phase_resistance": 0.03291689604520798,
        "direction": -1,
        "motor_type": 0,
        "current_lim": 10,
        "requested_current_range": 60,
        "current_control_bandwidth": 1000
    "controller": {
      "config": {
        "control_mode": 2,
        "pos_gain": 1,
        "vel_gain": 0.019999999552965164,
        "vel_integrator_gain": 0.10000000149011612,
        "vel_limit": 1000,
        "vel_limit_tolerance": 1.2000000476837158,
        "vel_ramp_rate": 10000,
        "setpoints_in_cpr": false
    "encoder": {
      "config": {
        "mode": 1,
        "use_index": false,
        "idx_search_speed": 10,
        "zero_count_on_find_idx": true,
        "cpr": 48,
        "offset": -23,
        "offset_float": -0.4937344193458557,
        "bandwidth": 100,
        "calib_range": 0.03999999910593033
    "sensorless_estimator": {
      "config": {
        "observer_gain": 1000,
        "pll_bandwidth": 1000,
        "pm_flux_linkage": 0.0015800000401213765
    "trap_traj": {
      "config": {
        "vel_limit": 20000,
        "accel_limit": 5000,
        "decel_limit": 5000,
        "A_per_css": 0
  "axis1": {
    "config": {
      "step_gpio_pin": 7,
      "dir_gpio_pin": 8,
    "motor": {
      "config": {
        "pole_pairs": 8,
        "phase_inductance": 0.000024654920707689598,
        "phase_resistance": 0.032729052007198334,
        "direction": -1,
        "motor_type": 0,
        "current_lim": 10,
    "controller": {
      "config": {
        "control_mode": 2,
        "pos_gain": 1,
        "vel_limit": 1000,
    "encoder": {
      "config": {
        "mode": 1,
        "use_index": false,
        "cpr": 48,
        "offset": -23,
        "offset_float": -0.4839375615119934,
        "bandwidth": 100,
      "config": {
    "trap_traj": {
      "config": {
        "vel_limit": 20000,
        "A_per_css": 0
M1 runs well in CTRL_MODE_VELOCITY_CONTROL with odrv0.axis0.controller.vel_setpoint = 1000.
M0 however will work at low speeds (around 50) but fail at higher speeds or after some time at lower speed, with motor error 0x10 / ERROR_CONTROL_DEADLINE_MISSED.
M1 generates the same error when it reaches higher speeds in CTRL_MODE_POSITION_CONTROL (e.g. when running to a posiiton setpoint far away).
My question is what does this error really mean (why would the control loop of one motor be so much slower that it misses the deadline) and how can I fix it?
Edit: I just noticed that axis0’s current_control_bandwidth was 1000 instead of 100. With 100, M0 will fail at speed 300 instead of 50.
 Good point.  One of UVW is plugged into Z, isn’t it?  I’m not sure then, I’ve never used the Hall mode.
