hello community,
i have odrive v3.6 of 56v which controls two same motors . well,I am giving both the motors same configurations but still when i give
odrv0.axis0.controller.input_pos = 10 and then 0 alternately
I am getting error of current limit violation in the motor at axis0 . well I tried to increase current control bandwidth and current limit but it was in vain.I also exchanged the axis and motors but then also I am getting current limit violation error
here I have mentioned all the details regarding to it
configurations :-
odrv0.axis0.motor.config.current_lim = 30
odrv0.axis0.motor.config.current_lim_margin = 20
odrv0.axis0.motor.config.calibration_current = 8
odrv0.axis0.motor.config.current_control_bandwidth =2500
odrv0.axis0.encoder.config.cpr = 8192
odrv0.axis0.motor.config.pole_pairs =7
odrv0.axis0.controller.config.vel_limit_tolerance=5
odrv0.axis0.controller.config.vel_limit = 50
odrv0.axis0.controller.config.pos_gain = 40.0
odrv0.axis0.controller.config.vel_gain = 0.2
odrv0.axis0.controller.config.vel_integrator_gain = 1
odrv0.axis0.controller.config.input_mode = InputMode.TRAP_TRAJ
odrv0.axis0.trap_traj.config.vel_limit = 40
odrv0.axis0.trap_traj.config.accel_limit = 50
odrv0.axis0.trap_traj.config.decel_limit = 50
odrv0.axis0.motor.config.resistance_calib_max_voltage = 10 #(phase inductance out of range)
odrv0.axis0.controller.config.spinout_electrical_power_threshold = 1000
odrv0.axis0.controller.config.spinout_mechanical_power_threshold = -1000
odrv0.config.brake_resistance = 2
uart configuration
odrv0.config.enable_uart_a = True
odrv0.config.gpio1_mode = GpioMode.UART_A
odrv0.config.gpio2_mode = GpioMode.UART_A
odrv0.axis1.motor.config.current_lim = 30
odrv0.axis1.motor.config.current_lim_margin = 20
odrv0.axis1.motor.config.calibration_current = 8
odrv0.axis1.motor.config.current_control_bandwidth =2500
odrv0.axis1.encoder.config.cpr = 8192
odrv0.axis1.motor.config.pole_pairs =7
odrv0.axis1.controller.config.vel_limit_tolerance=5
odrv0.axis1.controller.config.vel_limit = 50
odrv0.axis1.controller.config.pos_gain = 40.0
odrv0.axis1.controller.config.vel_gain = 0.2
odrv0.axis1.controller.config.vel_integrator_gain = 1
odrv0.axis1.controller.config.input_mode = InputMode.TRAP_TRAJ
odrv0.axis1.trap_traj.config.vel_limit = 40
odrv0.axis1.trap_traj.config.accel_limit = 50
odrv0.axis1.trap_traj.config.decel_limit = 50
odrv0.axis1.motor.config.resistance_calib_max_voltage = 10 #(phase inductance out of range)
odrv0.axis1.controller.config.spinout_electrical_power_threshold = 1000
odrv0.axis1.controller.config.spinout_mechanical_power_threshold = -1000
odrv0.config.brake_resistance = 2#(2 for odesc and 0.5 for odrive)
uart configuration
here are the phase resistance and inductance calculated for it
#phase resistance
axis0 0.07148325443267822
axis1 0.07039767503738403
#phase inductance
axis0 3.077850124100223e-05
axis1 4.213920692563988e-05
motor :-
maytech MTO5055-HA
encoder :-
cui amt 102
thanks ![]()
