I am a new oDrive (v3.5, 48V) user, and really happy with how it works and how well communication goes with the native protocol and the ASCII protocol.
I’ve found this Arduino I2C library, but can not wrap my head around how to implement it, so until now I haven’t tried if it works from scratch because I do not know what it will be doing.
I also tried to change the address manually by typing
In [12]: odrv0.system_stats.i2c.addr = 104
which is not a valid command.
Would appreciate any advice to get I2C running, so I can try out the commands specified in the Arduino library.
Unfortunately I am not familiar with STM32 programming.
In the Discourse #support chat, Oskar mentioned that one has to ‘desolder the can tranciever and make two bridge connections’, and I understand that this is for I2C. Right?
So it is impossible to use I2C out of the box? Or am I getting something wrong?
I’ve tried using the I2C. The odrivetool I2C stats are
Anyway I also tried with address odrive_num = 6, leaving out the read bit (LSB = 0).
Whatever address I put, I get the following result: Oscilloscope shows exactly the same signal (the 100 kHz clock signal) on both lines, exactly the same amplitude and phase.
Ia am using a Mega2560, with connections
SDA -> CANH
SCL -> CANL
Connected to another Arduino, my Mega2560 talks proper I2C
I tried also to switch the odrive on-board switch to CAN NO R, which just gave worse results (no clk at all).
The reason why I want to use I2C is a position update rate higher than 200 Hz for two motors, which I achieved with 1,000,000 Bd/s UART via ASCII protocol.
A hint where to work on or where I missed something would be awesome!!
With respect to your #1, I’d say that: yeah, he means you’d need to desolder the CAN IC (using a heat gun), then bridge the CAN H and L connections, such that when you hook up the CAN headers (schematic here: https://github.com/madcowswe/ODriveHardware/blob/master/v3/v3.5docs/schematic_v3.5.pdf), you are directly addressing the pins on the STM32 (which you enable using the function you previously experimented with). So…no, the I2C doesn’t work right out of the box - it requires some modification.
I’m not sure how to get it to work any further, as I haven’t played around with it yet or investigated it much myself. I’m going to play with it a bit right now, and spend more serious time looking into it tomorrow. I’m interested in perhaps using I2C to talk to multiple ODrives from a Mega, and am curious if that level of functionality exists and would work.
As I understand, for I2C communication, it is needed to remove the CAN transceiver (UI – VP232 chip) from the board and connect CAN D line to CAN H and CAN R line to CAN L. Then we can use I2C communication with Arduino or any other board with connections;
SDA -> CANH
SCL -> CANL
Hi!! This thread has been really helpful I need an i2c connection for a project I am working on but i have v3.6. I was hoping if you or anyone on this thread can help me out. Do I need to desolder the CAN H and CAN L connections on 3.6? I can’t find them. I think this board is slightly different and theres no schematic on github.
