Interpretation of Bandwidth Parameters
I’m playing around and tuning the ODrive for our system and want to make sure I understand the various bandwidth parameters: axis0.config.motor.current_control_bandwidth, axis0.config.encoder_bandwidth and axis0.controller.config.input_filter_bandwidth.
From the documentation, my understanding of axis0.config.motor.current_control_bandwidth is that the current controller is critically damped with a transfer function of w^2 / (s^2 + 2 * s * w + w^2) where w is axis0.config.motor.current_control_bandwidth. Is this correct? Is there any additional transfer function to be aware of between the current and applied torque or do we just scale by the torque constant.
Is it a similar case for axis0.config.encoder_bandwidth? I.e. the transfer function between actual rotor position and the rotor position output of the state estimator is also w^2 / (s^2 + 2 * s * w + w^2) where w is now axis0.config.encoder_bandwidth?
For axis0.controller.config.input_filter_bandwidth - is this just a first order low pass filter applied to commanded position with a transfer function of w/(s+w)?
Can I confirm that the units of all these parameters are radians/second.
Thanks for your help!
Hi!
From my rusty controls knowledge, this is correct :slight_smile: And yes, current to torque just scales by the torque constant (assuming you’re not hitting current/torque limits, your motor isn’t saturating, you’re not using field weakening, etc).
Not for this one – it’s a second order Luenberger observer, to allow for zero steady-state position lag. But yes, bandwidth given by encoder_bandwidth.
This is also a second order filter, it simulates a critically damped system moving to your input_pos, and uses that to generate a trajectory. Note it also generates velocity feedforwards and (if inertia is set) torque feedforwards, so it can really help with consistent performance while following a position-only trajectory.
All our bandwidth units are in “1/s” aka 1/τ (time constant) – which is the same as rad/s. We’ve historically had some issues with confusion as “radians per second” make people think of motor rotations :slight_smile: so instead we represent as 1/τ.
