Mks odrive s 3.6 has a schematic section in the files of this product, but there is no BOM list. Where can I learn the packages of resistors and capacitors in this product or where can I find the BOM list?
The BOM for the ODrive v3.4 and earlier is available in the hardware repository: GitHub - odriverobotics/ODriveHardware: High performance motor control
Note the MKS products are low-quality knockoffs, and are not genuine ODrives. I’d not recommend using them, I’ve never heard of someone having a good experience – seem to be more trouble than they’re worth.
I cannot buy odrive products in Turkey. If you can send them, I can buy them from you. I am trying to make my own clone since there are no sales. If you cannot send them, would you recommend me to make a clone of which product I will use for the steering wheel set? I would be grateful if you could share the schematic and pcb drawing of that product in the bom list.
Hi! You can order to international destinations via our worldwide shop. Note in the past we’ve had some customers who had issues importing to Turkey – the ODrive is not required to be CE certified as it’s technically a single component that must be certified in the context of the overall system, however this has caused some customs delays in the past, as they’re expecting all incoming items to be CE marked.
Well, if you have the pcb file of the odrive 3.6s model, can you share it, thank you.
Hi - you can see all public information here: GitHub - odriverobotics/ODriveHardware: High performance motor control
