Motor freaking out
Hi
My motor freaks out sometimes, how can I stop this from happening?
Full calibration: works
Putting it in closed loop control: works
But, when asking for a position, the motor sometimes just starts spinning way to fast, also when holding its position and you try to spin it, the motor sometimes just start spinning super fast and after one of those cases, the motor ‘craches’
Anyone who knows how to solve this?
Thanks
Cheers
Carelsbergh Stijn
I’ve had that happen when the cpr has drifted due noise in encoder signal. Do you have an oscilloscope to check encoder signal integrity?
I’ve had a similar issue which I describe here: Spinning after enabling closed loop control
Never got to figuring out why it’s happening though.
I have also been experiencing this. On 0.4.11, I see it occasionally after startup. On RazorsEdge, it happens if you manually rotate the motor shaft.
